Can not reset the oil service light
Old Nov 8, 2025 | 05:29 PM
Faast's Avatar
'91 964 Turbo, '02 E55's & '14 E63s-w
Looks simple enough
I have keyless go, so here's how I am doing it
Push the start button once
Get the mileage screen on
Press and hold the Phone and the Go buttons together and the menu should& would pop up
Here's where the the problem is..
As soon as I hold those buttons, The message with
Trip reset Yes/NO pops up
I have tried every possible way, including but not limited to, sitting in the passenger seat, sitting on the ****en top, standing facing away and towards the car but I just can't past that ****en message
Can anyone please help me
Old Nov 8, 2025 | 06:17 PM
PeterUbers's Avatar
Originally Posted by Faast
Looks simple enough
have you popped the start button out and just inserted the key fob and switched to ignition 1?
phone and OK buttons? (What's the go button?)
and you held phone and OK for like 10 seconds until service menu should pop up?
Old Nov 9, 2025 | 06:09 PM
Rehabguy's Avatar
E63S
I always have the Coolant and Oil temp screen on. So, I have to make sure I switch to the mileage screen before I shut down if I am to reset service light. Once shut down, push start button w/o pressing brake (ignition to position 1). Then press PHONE and within ONE SEC. press OK and hold both.
Old Nov 9, 2025 | 07:31 PM
FastWgn's Avatar
2016 E63 Wagon
I think you may have to use the actual key inserted, as outlined by Peter above.
Old Nov 10, 2025 | 01:37 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
STEERING WHEEL BUTTONS
This works nearly well. The issue is not keyless push-button but the interface of steering wheel buttons and CAN-B iCluster is not very stable.
I used to always get into shop-menu before starting the engine to monitor my chassis voltage + Amps
- Multiple keypress from right side button then couple from left side will gets menu opened if on the main mileage display.
RR pre-order showroom (HK Island)
