VGS (y3/8n4) with code U042600: The start enable signal was not issued by das
Old Dec 22, 2025 | 06:18 AM
Ayadizi's Avatar
2015 Mercedes E63s
Hello I got 2015 Mercedes E63s amg. I was driving nicely turned off the car. I come back car refused to go into gear. I got the code on the vgs (y3/8n4) is U042600: The start enable signal was not issued by ‘drive authorization system’. I have access to xentry offline (no coding) and a nice launch pad v scan tool with some coding. I also attached a live data line from xentry in the drive authorization section I assume the red NO should be a YES like xentry specified. I also changed my CAN signal distribution box (x30/21). I measured voltage from back probing the CAN box as well got good voltage for CAN high and low all around the box. My launch had a small option to teach in the drive authorization on the vgs but when I click on it says no communication but every other teach in process in the transmission does work and proceeds. I don’t know what to do? Any ideas?
Old Dec 22, 2025 | 06:13 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W212 AMG forum...
Old Dec 22, 2025 | 06:15 PM
Ayadizi's Avatar
2015 Mercedes E63s
Originally Posted by MJ50
moved to W213 AMG forum...
this is a W212 amg sorry I didn’t clarify!
Old Dec 22, 2025 | 06:16 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
updated
Old Dec 23, 2025 | 04:09 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
NO CRANK AUTHORIZATION
The drive authorization fails...it can be many items:
  1. Fob
  2. EIS
  3. ISM
  4. VGS
  5. (no ESL!)
  6. ...
-- Can you use your Xentry guided troubleshooting to pin point what actively acting up ??
-- You are showing 12.0V: low voltage impact unstable modules networking.
Charge up battery + reboot chassis fresh + clear faults.
Report progress.
