Solenoid replacement...car going to drop?
Old Jan 30, 2026 | 10:05 AM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
So, when I put this in (today) is the car going to drop to the ground as I disconnect the current solenoid? Not sure if I need to jack up the car or not...not like it is hard...I hate hate hate lifting the rear of the cars...
Old Jan 30, 2026 | 10:14 AM
RVAE34's Avatar
S212/M5T/Z31/240Z/3rd gen Tacoma
I suppose you are about to find out and report back with results lol!
Old Jan 30, 2026 | 10:22 AM
I am half invlaid this week. Got a cold/flu and last weekend was a bit less careful that needed on a trail....I dont need more drama....
Old Jan 30, 2026 | 11:38 AM
RVAE34's Avatar
Yikes! Stay safe!
Old Jan 30, 2026 | 01:13 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
NO AIR: FLAT
yes, you're right about your chassis dropping low without air-spring pressure.
Jack up the rear diff. and install jack stands at side lift points before valve replacement.
Use soapy water to double-check air connections while dealing with this.
Inspect & silicon lube your ride-height sensors to slow down the ball-joint rusting stuck.
Old Jan 30, 2026 | 03:16 PM
juststeve's Avatar
2012 E63 Wagon
the bags tend to collect sharp rocks and gravel in the folded area at each contact plate. with the car raised, a little compressed air can remove the dirt.
Old Jan 30, 2026 | 03:46 PM
air dryer renewal
There's a worthy maintenance procedure I don't know is the water condensate removal out of the Airmatic circuit...
Isn't there a DESSICANT bag that needs renewal so wet air doesn't have a chance to rust the steel valves + freeze in bags ??
In other words... bad valves are a marker of wet air, yes?
Dry AirMatic air is as essential as dry shop air to preserves air tools.
