Key battery warning
Old Apr 10, 2026 | 08:26 PM
E63SAMG2014's Avatar
2014 E63 / 2017 CLS 63 / 2015 G63
Key battery warning
Replaced with new duracell 2025. Still the same message….
again swapped out the newly placed battery thinking perhaps it’s the bad batch. With second new battery placed in, the same message.
what’s going on here?
Old Apr 10, 2026 | 11:43 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Fob Fault Reset
You'd expect the fault to clear itself with a good fob battery installed... not so quick!
The firmware requires a MANUAL RESET to clear low fob warning.
There is a weird service procedure to clear that. See youtube vídeo... I don't quite remember (key cycles On/Off/On) - I use CR2032 that last many years like most Jp cars.
Old Apr 11, 2026 | 06:41 AM
W205C43PFL's Avatar
Try a Panasonic battery as well.
Old Apr 11, 2026 | 05:05 PM
how to clear...
here is the weird reset procedure to clear warning msg:
fob warning clear
fob warning clear
enjoy MB ergonomics
Old Apr 12, 2026 | 10:56 AM
Rehabguy's Avatar
E63S
Interesting.
I never owned a car that chewed through as many key fob batteries as the W212 E63. I had success in getting rid of the message by simply swapping a new battery in the fob multiple times in the 7+ yrs I owned mine.
Old Apr 22, 2026 | 05:29 AM
fox3amg's Avatar
2014 E63s
I'm glad I found this thread, I thought my keyfob was defective.
I've tried various different brands, discounter, Duracell, Varta, etc... I feel like I keep changing the battery every 1-2 months.
Next time I'll try to put a CR2032, thanks @CaliBenzDriver for the tip. Didn't know it fits.
Old Apr 22, 2026 | 12:33 PM
Plan-B is best!
Where the setups lackluster, it's up to you to seek relief outside the factory limitations.
