Questions on Designo/custom order as a first time MB purchaser
how did the 9 speed MCT of the e43 amg feel compared to the 7 speed MCT in your 2014 e63 amg?
This transmission is not even close to the non MCT 7 speed in the S65 if you are looking for relatively quick and smooth shifts.
My biggest pet peeve about the 2014 E63S is that initial lag it has when flooring it from a complete stop (as a result of the TCU torque limits that are in place), i was wondering if the new MCT 9 speed also has that initial lag or does it launch hard similar to an audi quattro?
While the limiting in the 63 may be part of the TCU programming I think it is to protect the components in the AWD system. The 2WD S65 does not feel that way. Mash the throttle from a stop and all 738 ft-lbs of torque go straight to the rear wheels right now.
We watched eight of the YouTube videos on the E63 launch event at the track in Portugal. None of the magazine testers mentioned any drag start softness or delays. The Mercedes guys would of course not mention it if it existed. The new E63 has a lot more driveline programming options than the current edition. The Mercedes testers all enjoyed tracking the car in 2WD mode with the tail hung out. Bring lots of money for tires.
Not to bring up another sore point, but the E43 has Y rated EMT's (run Flats.) The E63 lists as standard equipment R01, High-Performance Summer Tires; and B51, TireFit Mobility Kit. So it appears the E63 like other true AMG's will not have EMT's.
The S65 doesnt have it because it uses a torque converter tranny which is able to handle higher torque in the lower gears without breaking anything. MCT is more sensitive to this, so to handle the torque of M157 in lower gears it must be restricted, hence the lag on all E63's from 2012+.
Im going to guess the new one still has it because its still not using a torque converter, so i dont know how the MCT can handle full torque in 1/2 gear without running into problems unless they maybe strengthened it to do so.
When i first saw the specs for the new E63s i was surprised to see the 0-60 nearly identical for both.
I'm also looking at low mileage used E63 wagons with the 5.5l turbo engine but euro delivery on a new one and a custom color would be very appealing.
I have the same feelings about the interior color choices, or better said, lack of. Hopefully 2019 and later will get more color choices for both paint and leather.
Everything at Sindelfingen and Graz production - S, E, CLS, G-class and GT - is available with custom options for both exterior paints and interior upholsteries. If the exterior paint is in the current or historical Mercedes-Benz palette, this makes it easier to secure the color. These custom options typically add 8 weeks to the production time, and your dealer can assist with this.
OP: What did you end up going with?
Thanks!
f.
Thanks!
f.
