Gremlins Got My Wagon
Old Nov 16, 2017 | 10:37 PM
2 '02 S600's Avatar
2020 E63S4S
Not even at 900 miles yet and got this tonight:
The AIR BODY CONTROL function is restricted. The vehicle's handling characteristics may be affected.
# Drive in a manner appropriate for the current level, but do not exceed 50 mph (80 km/h).
# Visit a qualified specialist workshop.
DYNAMIC BODY CONTROL is malfunctioning. The vehicle's handling characteristics may be affected.
# Do not drive at speeds greater than 50 mph (80 km/h).
Off to the dealership tomorrow for me!
Old Nov 16, 2017 | 10:42 PM
Vic55's Avatar
Administrator
Crap, hate seeing this, good luck
Im still getting my car
Old Nov 17, 2017 | 10:49 AM
24Hours's Avatar
2019 E63S wagon; 2016 Landrover Landmark
That sucks... good luck and I hope this is just a software issue. As far as your tire air pressure, did you try running closer to the 45-50psi like other folks? Any concerns with tire damage with lower PSI?
Good luck with the problems.
Old Nov 17, 2017 | 11:18 AM
2 '02 S600's Avatar
2020 E63S4S
Thanks, this morning the warning was gone when I started the car up, but I left the car with dealer to have them test system out and see what code was thrown, if they can pull it. Also having them look at the door checks up front since I am sick of dealing with the door coming back at me. I'll have new ones installed when I put my winter rims/tires on after thanksgiving.
As for the tire pressures, I have been running 38 when the tires are cold, they dropped to 36 with the cooler weather, as the picture shows, and I've been meaning to inflate them up again. They usual get to around 40 or so psi when they are nicely warmed up and I've had no issues. When I first picked up the wagon the tires were 41/42 cold and to me it was too much. I take the same streets usually so I know where the potholes, etc are and avoid them as best I can, so far so good on that front.
Old Nov 17, 2017 | 01:00 PM
Quickburn7's Avatar
2018 E63, 2008 SLR DH, 2011 599 SA, 1995 F50, 2007 through 2011 GT3 RS
I would have them replace the SAM module like they did on my car. Apparently when they did the emissions updates at the VPC if it wasnt done 100% correctly the car can start throwing errors and codes left and right.
Im running about 36 psi front and 33 psi rear cold. Got the best ride that way
Old Nov 17, 2017 | 04:56 PM
2 '02 S600's Avatar
2020 E63S4S
Just a call from my SA, the ABC module is going to be replaced (SAM module perhaps?), dealer placed order for a new one, as it appears to be a software issue with it. Supposedly a special case was opened on it, since it's the first they have seen with this. MB told the dealer to hold the vehicle until the module is replaced, hopefully Monday I'll get the car back. I'll follow up once this issue is resolved.
Old Nov 18, 2017 | 08:52 PM
adubm3's Avatar
2018 e63 wagon, R8 GT, 991 GT3, Golf GTI, Jetta GLI
Sorry to hear. Hope you get her back soon.
What is the production date of your wagon (approx)?
Old Nov 18, 2017 | 11:07 PM
2 '02 S600's Avatar
2020 E63S4S
July of this year is the production date of my wagon on the driver door frame.
Old Nov 30, 2017 | 05:35 PM
2 '02 S600's Avatar
2020 E63S4S
To update this thread I started. Took almost 3 weeks, but I got my car back this evening. The air body control (ABC) unit was found to have a fault code of C220C01 per my repair invoice, which pointed to a replacement of the ABC unit. They had to order one from Germany and program it and finally the car was fixed & back to normal. I hope no one else has this issue, since getting parts for these cars takes a long time. Of course, MBrace went nutty on the techs ride of my car & gave a message of "MB connect has limited service" and they had to recode that control unit as well.
Old Nov 30, 2017 | 07:51 PM
2012 merc amg's Avatar
2018 S560
Wow, I don't understand why they don't have more parts available, they have been making these cars in europe for a while. I've been waiting over a month for a simple Key that the dealer lost. They claimed there was none available in the USA or even Germany. God help anyone if they lost both keys, the car would be parked a long time. Mercedes needs to really step up and start having the dealers stock more parts for these cars like most car manufactures do. Sorry you had to wait so long to get this squared away, your problem was a lot more serious than my lost key issue.
Old Feb 24, 2018 | 06:37 PM
BACONMOTORSPORT's Avatar
2018 E63s Wagon
Has the Air suspension Malfunction stayed away? Mine came back...
Old Feb 24, 2018 | 07:06 PM
2 '02 S600's Avatar
2020 E63S4S
Knock on wood, no issues at all since I've had the wagon back. The new module and programming of it took care of the issue.
Old Feb 24, 2018 | 09:17 PM
jnolan's Avatar
‘17 Carrera GTS, ‘16 E63 Estate, 1965 Shelby Cobra and a few more
Mercedes needs to accelerate OTA updates for software
Old Jun 26, 2018 | 02:09 AM
roychimac's Avatar
2016 GLE 63S
My car is having the same malfunction at only 1300KMs. Build date was 04/18. Car is stock.
When the car is parked and off it sounds like the air suspension in the back is still making quite a loud noise - like it's trying to adjust.
Not sure what the problem is exactly but I'm going to bring it into the dealership soon.
