handheld lowering module
Old Jul 14, 2021 | 11:58 AM
  #276
Becksan's Avatar
2018 E43
Originally Posted by TugboatBill
Yes, it will ... unless you buy the proper a-arms. I've been lowered for about 8K miles and no wear problems whatsoever.
Was that using the lowering module too? Also what a-arms did you go with to avoid this issue? Thanks!
Old Jul 14, 2021 | 12:25 PM
  #277
TugboatBill's Avatar
2018 E63S Wagon, 2017 Z51 Corvette
Yes, with the lowering module. I lowered 25mm and did a 4 wheel alignment. In under 3K miles my fronts were toast. 8K miles later with the A-arms no wear problems.
https://mbworld.org/forums/w213-amg/...n-lowered.html
F1 is now at https://f1-fabrication.myshopify.com...ontpage?page=2
Although they don't list it, they do have them for the W213. You can contact them on their facebook page:
https://www.facebook.com/f1fab/
Part of getting new arms is a competent 4 wheel alignment, so include that in your budget.
Many thanks to ronin amg for pioneering this and sharing on mbworld.
Old Jul 14, 2021 | 01:39 PM
  #278
Becksan's Avatar
2018 E43
This is awesome! Thank you so much for sharing that - hehe yeah I'll def get an alignment done, don't want to change tires too often
Old Sep 11, 2021 | 10:57 AM
  #279
Adam Lang's Avatar
AMG E63s
Originally Posted by GlenKrok
Does it works on new facelift 2021 AMG E53?
guess so
Old Dec 17, 2021 | 08:38 AM
  #280
ShaneN.'s Avatar
2018 e63s edition 1
It appears like the default settings raises the car at 30 mph with the renntech lowering module, is that true? If that is the case, is it raising back to a stock height with huge wheel gap? For example of in dropped 20mm is it waiting thar 20mm every time I hot 30mph? Does anyone set their lowering modules, renntech or not, to not raise at any speed? Is there any negative to this other possible faster tire wear due to negative camber?
Also, for these cars sit lower in sport plus? Would a car parked in sport plus sit lower than if parked when last driven in comfort?
Just picked up a new car with a renntech lowering module and im trying to figure it all out.
Old Dec 18, 2021 | 01:01 AM
  #281
ShaneN.'s Avatar
2018 e63s edition 1
Lmao I jist realized by new car I bought that im asking about above was the original posters!
Old Jan 4, 2022 | 03:34 AM
  #282
ShaneN.'s Avatar
2018 e63s edition 1
If you perform wheel alignment after lowering, there will be no increased tire wear. Other problems are unknown to me.
These cars have enough adjustability to fix the added negative camber?
Old Jan 4, 2022 | 10:35 AM
  #283
I have added offset (+15mm front, +12mm rear) and with a 20mm drop and a full alignment I burned up the fronts in 2K miles.
With the same setup but with F1 Fab Adjustable A arms I've put on 10K miles with no unusual wear.
Added offset has an affect, as does how much you lower. No offset and 15mm drop there may be enough adjustability in the alignment settings to get a proper alignment.
Old Jan 5, 2022 | 02:14 PM
  #284
subiefiles's Avatar
2018 E63s wagon [now sold] (& lots of Subarus)
So if I buy one of these MB Star units and get the software working, that would replace the need for these silly one-off modules right?
example: https://www.vxdas.com/collections/mb...products/sd-c5
Old Jan 6, 2022 | 05:31 AM
  #285
K-Mac's Avatar
SPONSOR
Mercedes-Benz CLK 550
NO - THERE IS NO ADJUSTABILITY AT ALL ! - Background is W213 E43 / 53 / 63 AMG in fact all models the often quoted, reassuring:
"We Will Carry Out A Full Front & Rear '4' Wheel Alignment" in actual fact IS ONLY FRONT AND REAR TOE - "DIRECTIONAL" ADJUSTMENT !
Since the 90's there is no longer FRONT CAMBER AND CASTER TO ADJUST TIRE CONTACT ANGLES / spread load more evenly to cater for costly, premature edge tire wear through wheel squat brought about by load carrying or lowering, fitting wide profile tires, high cambered roads or even basic ongoing adjustability for curb knock damage. Excess edge load can also lead to ruptured side walls and rim damage.
New car industries best kept secret. All to do with cost cutting and the ever increasing speed of auto assembly lines.
We saw the need therefore to "reinstate both Front & Rear adjustment".
CLICK BELOW FOR COMPLETE RANGE OF OPTIONS AVAILABLE:
Spoiler
Old Jan 6, 2022 | 09:50 AM
  #286
Drewsky00's Avatar
2019 AMG E63 S
Spoiler
I know you've made this point several times before, but for those of us that are a bit denser, I must ask... your statement stands to reason that if you lower and/or add spacers with everything else staying the same, the old advice to have an alignment done to avoid further uneven wear is simply not valid, is that correct?
Old Jan 6, 2022 | 01:57 PM
  #287
subiefiles's Avatar
Their point is that even in stock form the car can't be aligned to prevent excess tire wear.
Sometimes the dealer might say "well they are set up aggressively from the factory" and other times if they see excess tire wear they might say "oh thats not right at all! it needs an alignment" and then they do an alignment and nothing changes because it cant actually be fixed
Old Jan 7, 2022 | 02:16 AM
  #288
K-Mac's Avatar
SPONSOR
Yes it is the best kept, closely guarded industry secret.
Reality is OEM (unlike the 90’s) there is only basic “Toe” adjustment !
It is obviously assumed by most - “surely there must be the ability to also ADJUST TIRE CONTACT ANGLES” Front & Rear (CAMBER adjustment) as well.
As explained - to spread load more evenly to resolve costly, premature edge wear caused by situations encountered in daily commuting..
Example altered height, subsequent wheel squat (Camber change) through load carrying or lowering, high cambered roads or simply having “ongoing adjustment” capability for curb knock damage.
KMAC - Resolving OEM Suspension Shortcomings Since 1964! AUDI to VOLVO
Old Jul 25, 2024 | 07:49 PM
  #289
egorijjj_mwmods's Avatar
IG: @loweredbenz
www.MWMods.com
Old Jul 27, 2024 | 10:45 AM
  #290
zukmeister's Avatar
2023 E63S AMG - Grey Magno
any discount codes for forum members?
Originally Posted by egorijjj_mwmods
Old Jul 27, 2024 | 11:19 AM
  #291
IG: @loweredbenz
Yes we offer cashback for few pics posted on the forum
Old Jul 27, 2024 | 12:06 PM
  #292
zukmeister's Avatar
can you pm me details please? Is it money toward future purchases or money off on lowering module at the time of purchase?
Old Aug 7, 2024 | 06:30 PM
  #293
IG: @loweredbenz
we return the cashback as soon as you provide us with the content with your car
Old Aug 8, 2024 | 01:15 PM
  #294
OrientBlue3's Avatar
ED1 e63S
Is there a promotion for MBWorld members available? 😏
Old Aug 9, 2024 | 04:06 AM
  #295
IG: @loweredbenz
Text us and we'll offer options to lower your price.
