Anyone got objective before:after numbers for their choice of tune?
It's about 45F here so horrible conditions but my Dragy GPS device (in which I have a good amount of faith based on live comparisons to Vbox and actual dragstrip time slips) recorded a 3.18s 0-60 using launch control. My ECU is enroute from Euro Charged in TX and will go back in the car sometime tomorrow at which point I'll try again.
Sadly, I have no pre-tune 1/4 mile times because I'm too impatient.
Im almost at 1K miles and intend to run the car to see where it is pre-tune within the next few weeks.
That said and to your question on detectability: I design security software for a living, if I want to know if it's been modified, there's no reasonable way for anyone to stop me (and I stress reasonable since "Mission Impossible" or hypothetical methods always exist). The question then is, do MB/AMG care? For the most part, BMW don't. In Audi's case, oh hell ya--they care... too much I think but that's their business model. According to my SA, MB is somewhere in the middle. I'm not really sure what to do with that information other than ignore it since I bought into the product knowing I'm going to tune it... wow, what a fundamentally useless response from me
Today, we use various "measurements" (hashes of the binary and the like) that are extended into a variety of different TPM (trusted platform modules... or hardware designed to create a root of trust) registers (PCRs). The TPM registers record the chain of events created by specific boot paths and the binaries that comprise that particular chain of events. We use code-signing certificates to generate white- and black-listed signatures of known software/firmware/TPM vendors (DB and DBX) to measure and attest to healthy firmware and the handoff from that healthy firmware to the OS loader. We ensure that the preceding binary in an OS' boot-chain is hard-coded with either a hash of the next trusted binary or, more commonly, the code-signing cert and file-metadata of the next binary in sequence. What you're talking about is prehistoric by today's standards--if I want to detect that you've modified a given OS' boot path, short of you compromising the firmware or the TPM or the CPU, it's not reasonable to prevent me from doing so. That's my only point here...
What tunes are available through your dealer?
P.S. And no, Magnusson-Moss does not apply to damage caused by an aftermarket ECU tune. The tune by definition causes the engine to operate outside of the design parameters imposed by the manufacturer. It has been tried.
Im curious about your previous experience with MM act. Was their litigation?
I can can confirm from a local dealer that Car will in fact be flagged if tune is done at dealer. Also, the ECU is physically opened up and it leaves evidence. Either way, there are can bus locations outside ECU that will store operating parameters of engine.
Under "CARS COVERED BY THE ORIGINAL VEHICLE MANUFACTURER’S NEW CAR LIMITED WARRANTY": ".. The Authorized Dinan Dealer will, without charge for parts or labor, repair or replace the defective Dinan component(s), as well as any original vehicle manufacturer’s component(s) that may have been directly affected by a Dinan component"
Brabus: http://www.g-center.nl/millenaar/dow...s-warranty.pdf
Relevant paragraph is highlighted in yellow. Their translation from German is not first-rate, but it definitely covers damage to other components, not just the Brabus parts.
Can't find Renntech with a quick Google search, but it exists and is very similar to the other two. Google is your friend.
I can personally attest that either family members or close friends / associates have indeed had engine work done or completely replaced and paid for by all three companies (Brabus was overseas).
