FS: Weistec catless DPs
Weistec downpipes webpage
Less than 2,000 miles driven?
Loved them, but way too loud in the apartment complex I live in. My neighbors are all more "senior" and I was getting complaints. So sadly they had to go.
$2,200 shipped within the USA.
I initially had my car taken to a place that cut the downpipes to remove them. This way you don't have to remove the transmission, steering rack etc. (TBH nobody has been able to tell me EXACTLY what has to be removed to do this work)
To put my stock DPs back in, they had to clean up the cuts, then add some v bands on each side and secure it. It works.
The other place that did the original work had planned to weld the pieces together in place. Remount the top, remount the bottom, clamp together, weld away. This would have been $500. Just have to be super sure the person doing it knows how to ground the operation correctly while welding.
The place that I ended up getting my DPs refitted, did a number on me about how the world will end if you attempt to weld items on a car, that it will fry all of your electronics. I've since heard from various people this might very well be BS. But too late now. So they did the v bands.
I think if you want to do it without cutting the DPs, yes you need to remove either the trans or steering rack.
I'm using a ECU tune to get around the CEL for the catless. If you're looking at a tune, I'd highly recommend a fellow here in the Bay Area who does hand tuned maps versus off the shelf products.
