Dragy results
#77
Next step is turbo upgrade. This 6.95 was on a 10.7 1/4 mile run. I can’t find what it was on my 10.6 run but probably marginally better. I think I will crack I tot the 5’s for 100-200 this year.
#80
any predictions on what turbos will do for you? maybe from 10.6s to 10.3s?
#83
You dont understand whats the CPC and how they comunicate with the other devices, You cant only do CPC and think now you can adapt you ECU and everything run how it should. Its a complex process where you have to adapt all ecu, tcu and cpc on the same line. You cant only do 1 device because the other one will block.
#84
I'd be curious to hear what tuner besides GAD is offering a TCU flash. Has anybody confirmed that there are also torque limits in TCU?
That would mean to get true stage 2 performance, you need 3 flashes: ECU, TCU, and CPC. Ouch!
Michael Khan (03-05-2020)
#85
#88
On dyno big numbers and on street slow.
6.7 its about 700hp +-
#89
2x upgraded high pressure pumps
1x Bosch spec high flow filter
1x Bluetooth ethanol content analyzer with mobile app
upgraded fuel lines
Cost of the kit is $3500
https://www.facebook.com/spoolauto/
I would message them, there website does not show it. I am trying to get word if E85 has been done on M177 yet.
expect labor quotes in ballpark of 2-6 hours
jerry from eurocharged is working on the tune. it sounds like we're limited by trans + cpc, as usual
upgraded fuel lines
#92
that about lines up with the 5.9s 100-200 times i’ve seen with stage 2 tune + downpipes + cpc flash
i wish i had better results to report on the cpc tune
i just have no clue how they are calculating/bypassing the digital signature. it’s very impressive.
with that dragy slip, do they say how much they paid for ecu + cpc tune? i am guessing $5k. i doubt the tcu was tuned as well.
#93
i could be confused but the current leaderboard shows this:
stock = 10.73s @ 128mph
a.rosto - 2019 e63s - 10.02s @ 140mph (GAD + ?)
skywalker - 2018 e63s 10.14s @ 138mph (renntech germany + turbos + ?)
rafa e63s - 2018 e63s - 10.22s @ 136mph (renntech germany + turbos + 102)
those stock times seem low, car and driver quotes 11.1s @ 126mph
Bones (01-22-2022)
#96
#97
Man... aren't you worried about the transmission handling the extra power of a Stage 2 build? That's what's stopping me from going the upgrade route with mine.
