E53 Oil Change Procedure
Old Jan 20, 2020 | 04:49 AM
bluepane's Avatar
Mercedes-Benz GLE V167 300d
Originally Posted by BenzC400
I’ll certainly share my experience with the 229.71 oil.
Any experience or information can share for us?
I will try 229.71 0w-20 on my 2020 GLE 300d V167 this week.
Old Jan 20, 2020 | 07:36 AM
BenzC400's Avatar
AMG CLE 53
Not much to share. Everything seems good. The operating temperature is the same. Gas mileage seems to be the same. The dealer put the recommended amount of oil in. A couple of weeks later I got a “reduce engine oil” message while driving at highway speeds. The dealer removed .2 quarts and all has been good since. I doubt the reduce oil message had anything to do with the type and grade of oil. The sensor is very sensitive and indicated the oil was filled to the MAX level when the oil change was done. It may have been a bit overfilled or maybe it expanded a bit at temperature and tripled the sensor.
Old Jan 20, 2020 | 09:31 PM
bluepane's Avatar
Got it and thanks for you update.
I really hope 0w-20 can have good mileage.
I will update my mileage test result soon.
