Stock dyno ('19 E63S)
The following 4 users liked this post by Res Ipsa:
2021 AMG GLE 63s Coupe AMG GLC 63s Coupe
Before you drop your money on a tune look into the peddlebox
https://www.pedalbox.com/en/mercedes.../pedalbox.html
My 2018 e63s wagon is tuned and my 2019 AMG GLC 63s coupe with just the peddlebox feels exactly the same due to the remapped throttle response ..
I won't be tuning my GLC now.
DriveAMG (07-12-2020)
ronin amg (07-09-2020)
you thought i was bad for crying about $7,000 in tunes
now we are down to $229 for a plugin that only "changes" it to feel faster, doesn't actually make it any faster lol
To be fair, it is strange to compare the pedal box to an ECU tune. Pedal box just changes the throttle position in relation to the actual pedal position (no actual performance improvement) where as an ECU tune actually increases HP and torque which will improve acceleration. Personally, I don't like devices like the pedal box because I prefer a linear throttle input. So if I press the throttle pedal 25%, I want 25% throttle, not 50% or whatever the pedal box is set to. If I want 50% throttle, I'll just press the gas pedal 50%.
kponti (07-14-2020)
Throttle input is a key factor in these ECU tunes, "feel" that you got something for your money.
Yes you don't get extra power but you will "feel" as though you did and after all that's what it's all about..
The best bang for the buck you can "feel" without needing a stopwatch to measure the tenths of a second 0-60 gains you can not "feel".
I'm not sure you've had one on a E63s before but if you did please tell me what your settings were because the throttle "feel" on my cars are exactly the same.
kponti (07-14-2020)
Nope, definitely would not spend money on one for my car after plenty of experience with them in other peoples cars. This is now very common from the factory on a lot of "lower powered" cars. Like I said, if I want 50% throttle, I'll just press the gas pedal 50%. The really annoying thing about these is that because they put the throttle in an exponential curve, the throttle "feel" in the later half (50% to 100%) is flat because it used the the otherwise % in the lower half to make it "feel" like you have more power. It's like putting a sticker over your stereo volume so that 25% volume is actually 50% volume. Sure, your stereo "sounds" louder but nothing has actually changed. I'm glad you like it but it's not for me.
Again in my opinion the best bang for the buck if you want to "feel" improvements and not void your drivetrain warrantee..
The following 2 users liked this post by ronin amg:
DriveAMG (07-12-2020),
TugboatBill (07-15-2020)
Nope, definitely would not spend money on one for my car after plenty of experience with them in other peoples cars. This is now very common from the factory on a lot of "lower powered" cars. Like I said, if I want 50% throttle, I'll just press the gas pedal 50%. The really annoying thing about these is that because they put the throttle in an exponential curve, the throttle "feel" in the later half (50% to 100%) is flat because it used the the otherwise % in the lower half to make it "feel" like you have more power. It's like putting a sticker over your stereo volume so that 25% volume is actually 50% volume. Sure, your stereo "sounds" louder but nothing has actually changed. With an actual ECU tune, it's like putting an amp on your stereo which actually makes the sound system louder. I'm glad you like it but it's not for me.
kponti (07-14-2020)
Yes, it was. You have to turn the car on (not the engine). Then you use the left scroll button on the steering wheel to open the odometer page; from there, there is a way to scroll to service mode, and you select "dynamometer mode".
Before you have an opinion
“These go to 11.”
https://youtu.be/uMSV4OteqBE
PS: In all fairness, an ecu reset gets it working well again
