M177 W213 Data Logger (aka know how much power your car actually makes)
Subscribe
Aug 4, 2020 | 11:03 PM
https://datazap.me/u/muffinflavored/runs-v2
I'm still tweaking it to have better units (PSI for boost for example) but... yeah. No JB4, no bFlash, no gimmicky Bluetooth OBD-II unreliable nonsense. Just take your laptop in your car and go
works with $15 Chinese Tactrix Openport clone
that's a stock run, i'm adding estimated/calculated rear wheel horsepower and all sorts of crap tomorrow
this doesn't use SAE J1979 identifiers that all of those iOS/Android apps do. I reverse engineered all of the German identifiers from Xentry for ECU/TCU/CPC_NG and figured out the scale factors to convert the hex into their appropriate human readable units
I need to fix ThrottleValvePosition so I can prove where CPC_NG does torque limiting when wide open throttle, and I need to increase the interval because right now it's at like 300ms (which is trash, needs to be 50ms-100ms)
Reply 4
Aug 6, 2020 | 06:34 PM
Is it going to work with all M177 equipped vehicles or just the W213?
Reply 0
Aug 6, 2020 | 06:50 PM
Quote: Is it going to work with all M177 equipped vehicles or just the W213?
i’m not really looking to sell it or distribute it
nobody on these forums really cares enough
probably 20 people on the forums run a tune and 0 of them need/want logs
it would work for c63s
Reply 0
Aug 7, 2020 | 12:59 PM
I'm one of those 20 lol.
Good work man, love the passion.
Reply 0
Aug 10, 2020 | 02:06 AM
here is some code for you guys
Code:
const calculateFactor = (min, max, size) => {
  const range = Math.abs(min) + max
  return range / (size == 1 ? 0xFF : 0xFFFF)
const scale = (min, max, size, value) => {
  const factor = calculateFactor(min, max, size)
  return (value * factor) + min
const scaleSigned = (min, max, size, value) => {
  if (size === 1) {
    const positive = (value & (1 << 7)) === 0
    if (positive) {
      return value * factor
    return (value - 0xFF) * factor
  } else {
    const positive = (value & (1 << 15)) === 0
    if (positive) {
    return (value - 0xFFFF) * factor
const formatGear = (value) => {
  return value
const formatRpm = (value) => {
  const min = 0
  const max = 16383.75
  const size = 2
  const unit = 'rpm'
  return scale(min, max, size, value)
const formatSpeed = (value) => {
  const min = 0
  const max = 4096
  const size = 2
  const unit = 'km/h'
const formatLoad = (value) => {
  const min = 0
  const max = 1536.00933
  const size = 2
  const unit = '%'
const formatTorque = (value) => {
  const min = -2048
  const max = 2047.9375
  const size = 2
  const unit = 'Nm'
  return scaleSigned(min, max, size, value)
const formatThrottlePedalPosition = (value) => {
  const min = 0
  const max = 100.006410
  const size = 2
  const unit = '%'
const formatThrottleValvePosition = (value) => {
  const min = 0
  const max = 6553.5
  const size = 2
  const unit = '%'
  //return scale(min, max, size, value) TODO: debugging
  return value
const formatAmbientPressure = (value) => {
  const min = 0
  const max = 2559.993705
  const size = 2
  const unit = 'psi'
  const scaledValue = scale(min, max, size, value)
  return scaledValue * 0.0145038 // hPa -> psi
const formatBoost = (value) => {
  const min = 0
  const max = 5119.921875
  const size = 2
  const unit = 'psi'
const formatWastegate = (value) => {
  const min = 0
  const max = 99.998474
  const size = 2
  const unit = '%'
const formatShortTermFuelTrim = (value) => {
  const min = -1536
  const max = 1535.953125
  const size = 2
  const unit = '%'
const formatFuelPressureHigh = (value) => {
  const min = 0
  const max = 32.7675
  const size = 2
  const unit = 'psi'
  return scaledValue * 145 // MPa -> psi
const formatFuelPressureLow = (value) => {
  const min = 0
  const max = 6553.5
  const size = 2
  const unit = 'psi'
  return scaledValue / 6.895 // kPa -> psi
const formatIgnitionTiming = (value) => {
  const unit = 'degrees'
  const min = -96
  const max = 95.25
  const size = 1
const formatTemperature = (value) => {
  const unit = 'C'
  const min = -48
  const max = 143.25
  const size = 1
const formatLambda = (value) => {
  const min = 0
  const max = 15.99054
  const unit = 'ratio'
  const size = 2
const formatIntakeManifoldPressure = (value) => {
  const min = 0
  const unit = 'psi'
  const size = 2
const formatMassAirFlow = (value) => {
  const min = 0
  const max = 6553.5
  const size = 2
  const unit = 'g/s'
  return scaledValue / 3.6 // kg/h -> g/s
const formatKnock = (value) => {
  const min = 0
  const max = 1
  const unit = 'flag'
  return value
// format is [requestArbitrationId, dataIdentifier, name, formatter, size]
module.exports = [
  // 1. general (gear + rpm + speed)
  [0x7E5, 0x6340, 'Gear', formatGear, 1], // Ganganzeige_aktuell_eingelegter_Gang
  [0x7E0, 0x2000, 'RPM', formatRpm, 2], // Motordrehzahl
  [0x7E5, 0x6346, 'Speed', formatSpeed, 2], // Fahrzeuggeschwindigkeit
  // 2. load
  // LoadAdapted Momentenadaption_Teillast
  [0x7E0, 0x2001, 'CalculatedLoad', formatLoad, 2], // Motorlast
  // 3. torque (target + actual)
  // TorqueReducedActual Momentenanforderung Durch Reduzierstufe Ist
  // TorqueReducedTarget Momentenanforderung Durch Reduzierstufe Soll
//  [0x7E0, 0x6000, 'EngineTorque', formatTorque], // Motordrehmoment
  [0x7E5, 0x6256, 'TorqueActual', formatTorque, 2], // Istmoment_Verbrennungsmotor
  [0x7E5, 0x6257, 'TorqueTarget', formatTorque, 2], // Sollmoment_Verbrennungsmotor
  //[0x7E5, 0x625A, 'CoordinatedTorqueTarget', formatTorque], // Sollmoment_aus_der_Momentenkoordination
  // 4. accelerator pedal
  [0x7E0, 0x2029, 'ThrottlePedalPosition', formatThrottlePedalPosition, 2], // Pedalwertgeber
  // 5. throttle valve
  // [0x7E0, 0xD023, 'ThrottleValvePosition', formatThrottleValvePosition, 2], // Drosselklappenwinkel
  // 6. boost (target + actual)
  [0x7E0, 0x2040, 'AmbientPressure', formatAmbientPressure, 2], // Umgebungsdruck
  [0x7E0, 0x2018, 'IntakeManifoldPressure', formatIntakeManifoldPressure, 2], // Saugrohrdruck
  [0x7E0, 0x207A, 'BoostActual', formatBoost, 2], // Ladedruck_korrigiert
  [0x7E0, 0x2077, 'BoostTarget', formatBoost, 2], // Ladedruck
  // 7. wastegate duty cycle
  [0x7E0, 0xD062, 'WastegateDutyCycle', formatWastegate, 2], // Wastegate
  // 8. fuel trims (short term)
  [0x7E0, 0x6088, 'ShortTermFuelTrim1', formatShortTermFuelTrim, 2], // Gemischadaption_Additiv_Lernwert_Links
  [0x7E0, 0x6087, 'ShortTermFuelTrim2', formatShortTermFuelTrim, 2], // Gemischadaption_Additiv_Lernwert_Recht
  // 9. fuel pressure (high + low)
  [0x7E0, 0x2071, 'FuelPressureHigh', formatFuelPressureHigh, 2], // Kraftstoffdruck_Hochdruck
  [0x7E0, 0x2098, 'FuelPressureLow', formatFuelPressureLow, 2], // Kraftstoffdruck_Niederdruck
  // 10. ignition timing
  [0x7E0, 0xD010, 'IgnitionTiming', formatIgnitionTiming, 1], // ROZ_Korrektur_Zundwinkelausgabe
  // 11. temperatures (ambient + coolant + intake + oil)
  [0x7E0, 0x5030, 'AmbientTemp', formatTemperature, 1], // Aussenlufttemperatur
  //[0x7E0, 0x2013, 'CoolantTemp', formatTemperature, 1], // Kuehlmitteltemperatur
  [0x7E0, 0x2014, 'IntakeAirTemp', formatTemperature, 1], // Ansauglufttemperatur_im_Saugrohr_Bank1
  //[0x7E0, 0x2095, 'OilTemp', formatTemperature, 1], // Oeltemperatur
  // 12. afr / lambda (before kat = wideband; after kat = narrowband)
  [0x7E0, 0x6252, 'MassAirFlow', formatMassAirFlow, 2], // Luftmasse_Vorgabe
  [0x7E0, 0x2046, 'LambdaAcutal1', formatLambda, 2], // O2_Sonde_Vor_Kat_Lambda_Recht
  //[0x7E0, 0x2047, 'LambdaAcutal2', formatLambda, 2], // O2_Sonde_Vor_Kat_Lambda_Links
  [0x7E0, 0x6144, 'LambdaTarget1', formatLambda, 2], // Lambda_Sollwert_Links
  //[0x7E0, 0x6143, 'LambdaTarget2', formatLambda, 2], // Lambda_Sollwert_Recht
  // 13. knock
  [0x7E0, 0x2006, 'KnockSensor', formatKnock, 1], // Klopfsensor
Reply 1
Aug 10, 2020 | 02:08 AM
the ISO-TP/UDS code to group 20 data identifiers into 1 request to make data logging/polling much faster:
Code:
const { isoTpSend } = require('./iso-tp')
const startDiagnosticSession = async (device, arbitrationId, mode) => {
  return isoTpSend(device, arbitrationId, 0x10, [mode])
// do not define more than 20 to one data identifier
const dynamicallyDefineIdentifier = async (device, requestArbitrationId, dataIdentifier, definitions) => {
  const output = []
  output.push(0x01) // defineByIdentifier subfunction
  output.push(dataIdentifier >> 8) // dynamicallyDefinedDataIdentifier
  output.push(dataIdentifier & 0xFF) // dynamicallyDefinedDataIdentifier
  for (let i = 0; i < definitions.length; ++i) {
    const definition = definitions[i]
    const definitionDataIdentifier = definition[1]
    const definitionSize = definition[4]
    output.push(definitionDataIdentifier >> 8) // sourceDataIdentifier
    output.push(definitionDataIdentifier & 0xFF) // sourceDataIdentifier
    output.push(0x01) // positionInSourceDataRecord
    output.push(definitionSize)
  return isoTpSend(device, requestArbitrationId, 0x2C, output)
const clearDynamicallyDefinedIdentifier = async (device, requestArbitrationId, dataIdentifier) => {
  const output = []
  output.push(0x03) // clearDynamicallyDefinedDataIdentifier subfunction
module.exports = {
  startDiagnosticSession,
  dynamicallyDefineIdentifier,
Reply 0
Aug 10, 2020 | 02:11 AM
some bull**** formula i found online to calculate realtime horsepower/volumetric efficiency/load estimates given airflow + temperature + barometric pressure:
Code:
// from https://atgtraining.com/atg-volumetric-efficiency-calculator/
const calculateVolumetricEfficiency = ({engineSize, cylinder, drivetrainLoss, rpm, maf, iat, pressure, mafSelection, iatSelection, pressureSelection}) => {
  let val = 0, cid = 0, lb = 0, degc = 0, degf = 0, tempK = 0, v = 0, molorMass = 0.28705, gb_air_vol = 0, gsec = 0
  let gb_theo_air_vol = 0, lMin = 0, estV = 0, load = 0, cylAir = 0, refCylAir = 0, estGross = 0, estRWHP = 0
  cid = engineSize / 0.0163871
  if (mafSelection == 'g/sec') { // g/sec
    lb = maf * 0.00220462 * 60
  } else { // lb/min
    gsec = maf / (0.00220462 * 60)
    maf = gsec
    lb = gsec * 0.00220462 * 60
  if (iatSelection == 'F') { // fahrenheit
    degc = (iat - 32) * 5 / 9
  } else { // celsius
    degf = iat * 9 / 5 + 32
    degc = (degf - 32) * 5 / 9
  tempK = degc + 273.15
  degc = (degc).toFixed(2)
  tempK = (tempK).toFixed(2)
  if (pressureSelection == 'kPa') { // kPa
  } else if (pressureSelection == 'in/hg') { // in/hg
    pressure = pressure / 0.2953
  } else { // psi
    pressure = pressure / 6.895
  v = (maf * tempK * 0.28705) / pressure
  gb_air_vol = v * 60
  gb_theo_air_vol = engineSize * rpm / 2
  estV = (gb_air_vol / gb_theo_air_vol) * 100
  cylAir = maf * 120 / (rpm * cylinder)
  refCylAir = engineSize * 1.168 / cylinder
  estGross = lb * 10
  estRWHP = estGross * (1 - drivetrainLoss)
  load = (cylAir / refCylAir) * 100
  return {
    volumetricEfficiency: estV,
    theoreticalLoad: load,
    whp: estRWHP
module.exports = {
if anybody with a tactrix openport wants the code hit me up, i'll share how to set it up. it's slick and it's better than HP Tuners (they use OBD service 01 which is ***/trash/slow/incomplete compared to this)
probably as good as bFlash/Autotuner, better/as good as JB4 without the cost or having to hook up crazy **** to your car
https://datazap.me/u/muffinflavored/...log=0&data=3-5
updated logs, much better frequency/logging. i'm convinced you don't even need dragy. i can read the spedometer every 10ms. traction isn't really an issue 100-200km/h AWD so... i'll do some tests to compare how close they are in terms of accuracy (GPS vs OBD, which would be powering the dash)
Reply 0
Aug 10, 2020 | 10:17 PM
Quote: some bull**** formula i found online to calculate realtime horsepower/volumetric efficiency/load estimates given airflow + temperature + barometric pressure:
Code:
} else { // lb/min
maf = gsec
} else { // celsius
} else { // psi
gb_air_vol = v * 60
estGross = lb * 10
return {
whp: estRWHP
module.exports = {
Very nice log! I like the parameters, esp boostactual and boost target..
Reply 0
Explore
Aug 10, 2020 | 10:44 PM
Quote: Very nice log! I like the parameters, esp boostactual and boost target.. I use HP tuners, and non of that is available, man would that be great to have.
Great work here!
thanks man! please, buy a $15 chinese tactrix openport and use my code. you’ll love it, i promise!
Reply 1
Nov 25, 2020 | 10:59 AM
Quote: thanks man! please, buy a $15 chinese tactrix openport and use my code. you’ll love it, i promise!
Thanks man!!
Very interesting post.
I will to buy one.
This is valid? --> https://es.aliexpress.com/item/33019...archweb201603_
Reply 0
Dec 2, 2020 | 01:08 AM
some pretty pictures to prove she works
makes JB4 look stupid! jk :P
Reply 1
Dec 6, 2020 | 04:24 PM
i have tactrix openport2.0
can you tell me how to use the code to datalogg :-)
Reply 1
Dec 10, 2020 | 03:33 AM
Code:
} else { // lb/min
maf = gsec
} else { // celsius
} else { // psi
gb_air_vol = v * 60
estGross = lb * 10
return {
whp: estRWHP
module.exports = {
Hello,
Can you explain how to make the logs?
Thank you.
Reply 1
Aug 1, 2024 | 10:36 AM
BUMP! Back from the dead!
Beuller? Beuller?
Reply 0
Oct 15, 2025 | 02:02 PM
Damn I am late to this party/thread. Are you still around here and able to share how to go about this procedure? Cheers
Reply 0
Subscribe
Currently Active Users (1)
