Auto Start/Stop Problem
Has anyone experienced this and is there a solution other than going to the dealer? Any input is appreciated. In the meantime I will turn off the feature.
it’s obvious you need to take it not your dealer ASAP as this can be a safety hazard (car behind you can literally hit you assuming you are to go I green light). In the meantime, I suggest to disengage ***.
Has anyone experienced this and is there a solution other than going to the dealer? Any input is appreciated. In the meantime, I will turn off the feature.
Keeping to search for a better solution. Very appreciate your sharing and suggestion, if any.
(un)Luckily for me my battery is so rarely fully charged up, that my start/stop hardly ever activates. Early next year I am moving and doubling my commute to four miles, so perhaps I'll need to contend with it more. The drive unit controls make it about as easy as you'd hope it to be.
The dealer chalked both issues up to a failing battery and replaced it. Others have stated that the as/s problem could be starter related. If it happens again I will make a further update.
In addition to that problem, I have recently had an issue where once every 2 weeks or so all the safety systems would go offline.
A simple restart of the car would solve that problem.
Let's string all the pieces together towards a fix:
- Low battery disables EcoS/S
- Sometimes restarts impossible
- Random "xyz safety disabled" errors
- Sometimes limp modes strike
When the alternator output drifts near 11V it's only the tip of the iceberg!
The hidden part are the CAN disruption that corrupt the charging system and cause F-SAM to get sleepless.
Replacing batteries and starters wasted prematurely is silly
MB checked & confirmed my Starter Motor is fine. Another Dealer even looked into my ECU unit. All efforts were in vain. I have to remember to turn off the Auto Start/Stop button, else I will faced the same problem. Your advice to the solution please!
