Stage 2 E63s losing fuel on high rpms
How do I disconnect the Lin ? I’m having the same issues as listed above.
[How do I disconnect the Lin ? I’m having the same issues as listed above. QUOTE=CaliBenzDriver;8591037]NONE, pure bliss!
Having the alternator supplying the car directly instead of ghosting will give you intended performance and save you bundles in uneeded services.
> Say goodbye to... :
moody engine performance
crashed F-SAM draining battery
limp modes on low voltages
prematurely wasted battery
starters wasted on high currents
PreFuse toasted with 1,000W (1KW!)
> Take a look with IC Display:
-- Once the battery is done absorbing a charge current it will be transparent with near zero load.
-- Alternator voltage is internally regulated between 14.4V and 13.7V.[/QUOTE]
> Say goodbye to... :
Received 3,772 Likes
MY'14 W212 M276 3.5NA @60kMi
ALT self-control....
Serial LIN bus is the skinny control wire connector on the alternator (NOT the fat red output power).
When the Bosch engine computer is unable to reliably control alternator... we are forced to seek experimental solutions
