2018 e63s W213 Brake Rotors and Torque Specs
Time to change the brakes (all the way around). Found FCPeuro has the Brembo retrofit 2 piece rotors for significantly less than the 1.5 OEM. Anyone try these? Are they at least as good as the OEM?
are there any other brands or kits to consider?
Also trying to find a guide with the torque specs to change the pads and rotors on my own.
dealer quoted $4k for just the front pads and rotors
thanks!
thanks!
Received 3,870 Likes
2017 GLE350 4MATIC
thanks!
thanks!
Caliper bolts need replaced. They are single use fasteners.
18e63 (11-04-2022)
I’m using the brembo 2pc fronts on my 212 wagon. Rotors in rear too. Got mine from Newparts.com.
Pads can be any, either Brembo or couple others. Rear brembo pads don’t seem available in US.
Rotors great. Better than stock.
18e63 (11-05-2022)
I got my front ones replaced with FCP brembos both disks and pads , and I did rear pads only keeping stock rotors just changed pads , works with no issues , I’m at 50k miles , will replace rear rotors next time with new brakes pads provably around 80k , rears seem to last longer , I did not resurface old rear rotors just installed new pads on top
saved ton of $ and works with 0 issues
I have, it's very easy and can be done on their web-site just need to reference you past order (what you are returning) and a newer order (for same product) then you return the parts and get store credit. I even send back oil and get credit within a day of receipt.
