E53 Coupe: PA5 Tire size issue. Better alternatives?
How big of an issue is this? Can I get 4 x 245/235 R20 95 V XL PA5s and call it a day and move on with my winter wonderland driving? Or is there another size I should look from the PA5 range for the rear tire but from I can see there doesn’t seem to be one unless my over thinking of this has corrupted my ability to use basic math.
By going square , you will have to take note on how the tire shop changed out your wheels, that is, making sure the correct front wheels go to the front and rear wheels go to the rear, otherwise, you may run into clearance issue with suspension when the wrong offset wheels are put into the front.
I suggest to use some masking tape and write on the tape as front & rear so that it would be easier for the shop not to mix them up.
Package includes:
Front - MSW (by OZ)MSW (by OZ) 30 19x8 (5x112) x 2 Colour: Gloss Black Diamond Lip
Rear - MSW (by OZ)MSW (by OZ) 30 19x9 (5x112) x 2 Colour: Gloss Black Diamond Lip
Front - Continental245/40R19 CONTINENTAL WINTERCONTACT TS 860 S x 2
Rear - Continental275/35R19 CONTINENTAL WINTERCONTACT TS 860 S x 2
£2,308.00
Add:
Tyre Pressure Monitoring System (x4)
- AccessoryTyre Pressure Monitoring System x 1 £155.00
SUBTOTAL £2,463.00 inc. VAT
https://www.lkperformance.co.uk/whee....0&rear=19x9.0
Yeah, the issue was I was looking for the upgrade 870 P as it was the upgraded version and for some reason sorely lacks in size diversity in comparison to the 860s. I'm probably over thinking but the latter's testing data with it being decently worse in the wet over the former (and I'm Belgium so... many rain shall fall) concerned me, but maybe it should not.
-> Essentially I have to decided between: 1) square the AP5s, 2) take a look at alternate size fittings from the 870 P to see if something fits closely, or 3) look at 100% matching 20" sizes from the 860s or the VREDESTEIN WINTRAC PRO but not to keen on that as we do get some snow in the south. Tough between 1 and 3. Ironically the HANKOOK WINTER ICEPT EVO3 have the rear 275/30 R20s but not the 245/35s! Offset sizes OP.
Just looking for tires at the moment as I'll try snacking new wheels for the summer. Didn't feel like splashing on 19" winter rims for 3-4 months if there were 20" winter tires that could do the job on the OEM rims and I can get exactly what I want for summer wheels in April!
I have PA5 on 19" square and I like them, previous winter was Conti 850P which also served me well for 4 winters
I asked for further clarification as in: you just don't have the rear fit, that's okay, can you put them on square? or you literally won't do it even if you have the tire/I bring my own?
Essentially they told me to LM005 of Wintrac Pro. Might just have to ride with the latter and enjoy the dry/wet performance and avoid the deep snow drag races.
Also I have to order a special TPMS for the E53 from Mercedes directly, apparently.
mb does not use proprietary tpms. Lol. If mb uses 433mhz, this same parts can be used on a bmw as well.
Do you perhaps know what sensor kit I'd need for the E53 Coupe? This was where I was ignorant as I thought they'd just supply it and I've never had to look it up before.
Doing LM005 vs Hankook Icept Evo 3 vs Wintrac Pro comparisons now but 100% over thinking at this stage. Will ask another few shops about PA5 square though and see where we get.
https://catalogue.schradertpms.com/e...009052102.html
Why do you need another set of tpms to begin with ?
your factory setup now has tpms in the wheels already. You are just removing the current tires and put in winter tires .
see .. your tire shop is giving you more bs
Original:
"Ce n'est pas autorisé à mettre la même taille de pneus partout. Si vous me dite le contraire et que vous en êtes certains, merci de nous envoyer le certificat de conformité pour le vérifier mais pour moi ce n'est pas correct surtout sur ce genre de véhicule bien spécifique."
Translation:
"It's not allowed to put the same tire size everywhere. If you tell me otherwise and you are certain, please send us the certificate of conformity to verify it, but for me it is not correct, especially on this type of very specific vehicle."
From whom do I need such heavenly authorization
My Merc dealer probably will have the same attitude considering 'factory settings'. Really weird. Anyway, considering it's officially getting rainy and cold, I think will try the Wintrac Pros given they do a solid job in said weather (LM005 are good also but some have commented on it being a bit boring including Tire Reviews) and apparently are a fun wheel to drive. Here's to hoping next year the 870P or PA5 come in my size!
w213 e63s first came out with square factory winter setup in 2018 and then subsequently offers both square and staggered.
Many of us are using square…and we are still here 😁
this is get better and better …, 😄
i suggest you to simply move on with this clown shop.
