Uneven wear on stock car
Old Apr 28, 2023 | 11:53 AM
lyjw88's Avatar
C63s ED1 Coupe
Is it normal to see excessive inner front tire wear on a car at stock height? Took off my winter setup and it’s pretty bad after one season.
Old Apr 28, 2023 | 01:32 PM
b0rderman's Avatar
E63S Wagon
It is normal for stock alignment and setup.
This is a good reminder for everyone to park their car at full steering lock next time you pull into your driveway, just to check that inside shoulder. The outward half of the front treads tell you nothing about the current life of your tires on these cars.
Old Apr 28, 2023 | 01:38 PM
Keith66's Avatar
2018 AMG E43
Shouldn't be normal for any car. Depending on the wear pattern, either your camber or toe is not optimal.
I'd take it to a reputable alignment shop. The camber can't really be adjusted on our cars, but a good camber adjustment kit is well worth the money if you need it. A lot cheaper in the long run than contunually replacing tires with tread life on them.
Old Apr 28, 2023 | 04:29 PM
bobblehead's Avatar
go fast grocery getter wagon
Op, you are not alone.
there are many threads that talked about this irregular wear due to factory camber setup
Old Apr 28, 2023 | 06:50 PM
RevisionCuda's Avatar
W213 E63S Wagon
cant do anything about the camber unless you get after market.
what you can do is zero out the TOE.
Old Apr 29, 2023 | 05:10 AM
ygmn's Avatar
2015 E400 Sedan
for rears as well.
Plenty of aftermarket solutions.
I have same problem with rears.
Outer tread is about brand new and inner tire is worn to belts.
Eat tires like crazy - no tire life.
I am looking at site sponsor K-mac as they are basically eccentric bushings to allow aligner some adjustment,
Other type is adjustable upper bar link for rear.
front and entire different beast.
If you track it they all different types of kits.
I am sure k-mac will post in this soon or go find his posts and links good info
Old Apr 29, 2023 | 08:15 AM
lyjw88's Avatar
C63s ED1 Coupe
I’m aware of the aftermarket solutions but can’t justify it since the car is not even lowered…
Old Apr 29, 2023 | 09:05 AM
bobblehead's Avatar
you just going have to replace tires every two years or so ... I am in the same position too .... inner front wear is worse than the inner rear wear.
so, do inspect your tires at least once a year.
Old Apr 29, 2023 | 11:16 AM
Keith66's Avatar
2018 AMG E43
I highly recommend K-Mac, high quality and heavy duty kit.
My W205 would eat rear tires for breakfast, inner edges. The car should've just shipped with bicycle wheels and tires, cause that's the only width of tire it used, lol.
I did the K-Mac camber kit and after ~5K on new tires, the wear was perfectly spread across the tread. Camber was set at 0.5% negative and zero toe.
Parts and labor was around $650 to fix it forever, opposed to buying $700 worth of tires every 8K miles. Also don't lose sight of the safety aspect of this issue too. I know I'm not comfortable riding and chewing up my inner tire edges at freeway speeds, hoping I still have enough cords to keep me out of a ditch.
Old Apr 30, 2023 | 05:05 AM
ygmn's Avatar
2015 E400 Sedan
well said Keith.
MB designs and builds them without ability to adjust camber so pure luck on what you get.
My fronts seem to be OK and wear good the rears - arggggg.
Dealer said nothing they could do nor would do other then sell me new tires.
Local shops said they cannot adjust as it is nothing they could do so they walked away so to speak.
Soon I will buy the kit and have installed and tires aligned for better life as I am not racing this LUXURY car.
Old Apr 30, 2023 | 05:33 AM
K-Mac's Avatar
SPONSOR
Mercedes-Benz CLK 550
Yes either showroom height or lowered:
The reality is day to day commuting encountering high cambered roads with excess passenger side edge wear or Camber change through altered height - load carrying or lowering. Fitting wide profile tires or curb knock damage.
No longer is there ongoing adjustability for Camber (or Caster). Only basic Toe (directional) adjustment !
It is all to do with cost cutting and ever increasing speeds of new car assembly lines.
FOR ALL MODEL W213 WE THEREFORE MANUFACTURE COMPLETE RANGE OF FRONT AND REAR KITS.
Example Front and Rear “UPPER ARM” or “LOWER ARM” adjuster kits.
Background is “Upper Arms” are more difficult to fit and adjust. Also when wanting to resolve Costly, Premature excess inner edge tire wear arms need to adjust outwards reducing important clearance top of tire to outer fender.
While “Lower Arm” adjusters retain this clearance along with Front and Rear Camber adjusters CAN BE FITTED WITHOUT NEED FOR CONTROL ARM REMOVAL.
Also the unique K-MAC “Patented design adjustment system” has eliminated the need for time consuming disassembly to allow Camber change.
NOW IT IS PRECISE SINGLE WRENCH “ULTIMATE ADJUSTMENT” - DIRECT ON ALIGNMENT RACK “UNDER LOAD”.
SEE SPOILER RE W213 FRONT & REAR KITS.
Spoiler
Kevin
AUDI to VOLVO - K-MAC Experience Of Resolving OEM Suspension Shortcomings Since 1964 !
Old Apr 30, 2023 | 04:34 PM
Ed99's Avatar
E63s AMG
Spoiler
Kevin
We should get a group buy for this!!! I would be interested if so!!!
Old May 1, 2023 | 08:57 AM
HBerman's Avatar
2024 AMG EQE SUV , 2021 E63S Wagon - gone, 2018 E63S Sedan - gone
I have 15500 miles on my Michelin P/S4 A/S on my 2021 E63S wagon. My latest service inspection showed even wear across both rhe front and rear tires. However, the tread depth on the passenger side both front and rear was 1mm less than that on the driver side. No explanation from the tech that did the measurements. I don’t see any unusual shoulder wear on the inner part of the fronts either. I wonder how much the difference in tire construction contributes to the shoulder wear being seen by others.
Old May 1, 2023 | 09:10 AM
bobblehead's Avatar
that's good you are not showing inner tire wears for front & rear. I am already on my second of PS AS4 (having replaced 2 seasons after the first due to inner wear problems).
Old May 1, 2023 | 11:20 AM
E634Me's Avatar
Veteran: Army
2018 E63S AMG
I'm on my third set of front tires at 22,000 miles. Just had the car in for annual service and replaced the fronts with new PS4s. Original Pirelli tires lasted less than 10,000 miles, front tires were done on the inner edges, rear had life left in them. Replaced with PS4s all around at that time.
The Michelin front tires went a bit over 12,000 but I wasn't driving the car as hard during this set as I did the original tires, more mountain runs and fun. More daily commuting and easy road trips on the second set. Rear tires still ok despite some good heavy throttle time spent in race mode around my favorite corners. Dealer didn't have a problem with me replacing only the front tires.
Old May 1, 2023 | 12:12 PM
HBerman's Avatar
Hmm..... I drive in sport mode for the engine/transmission and comfort mode for the suspension. I wonder if the lowering that happens with the Sport mode suspension setting is contributing to the tire wear.
Old May 1, 2023 | 12:37 PM
bobblehead's Avatar
I would imagine if anyone lowered the car, the wear may accelerate even faster ?
Old May 1, 2023 | 01:24 PM
Keith66's Avatar
2018 AMG E43
Since the suspension travels in an inward arc, any compression of the suspension causes the wheel to go more negative in camber, so yes, this can be a contributing factor. However, it depends on your reference point. If in Comfort your camber is good for tire wear (say 0.5-1.0 negative), lowering by 15-20mm I don't think would have much impact, but if your baseline camber is say 2%+ negative, lowering 15-20mm will compound the inner wear at a greater rate.
Absolutely. IMO, if you lower a car without correcting the camber, you didn't do it right. Lowering most cars more than an inch and you can see the negative camber with the naked eye.
I'd like to add that the comments and opinions I'm making here are focused on optimizing tire wear, not focused on squeezing out maximum handling performance or tracking the car. If you spend most of your time carving twisties with maximum thrust or track your car often, you'll probably want 2%+ negative camber and 1/8-1/4" toe in. But if you drive your car like that most of the time, you'll use all of your tire and wear them out long before you'll see the effects of negative camber in street driving.
I don't know about you guys, but the majority of my driving is not tearing up corners at warp speed, lol.
Old May 1, 2023 | 01:33 PM
E634Me's Avatar
Veteran: Army
2018 E63S AMG
I drive in Comfort mode most of the time (exhaust in sport of course) and have Individual mode programmed essentially for Race mode. That way it is just a single click to get to Race mode when something interesting is afoot. Following that I drop it back to Comfort mode and hit the exhaust button.
So at least for my case I don't think it is ride height that is impacting the tire wear - I'm sure it's the aggressive camber.
BTW, suspecting as much, I had the car in Race mode and surprised the heck out of Tesla Model 3 yesterday who foolishly thought they would pull me after the light changed to cut over to the Interstate on-ramp lanes. Nope, they had to merge behind me
Old May 17, 2023 | 04:35 PM
subiefiles's Avatar
2018 E63s wagon [now sold] (& lots of Subarus)
The dealer will tell you "they shouldnt wear like that" which is a reasonable assumption (classic dealerships, just assuming everything), however if you press them for solutions they wont have any, because it is how the car is designed and there is nothing they can do.
Factoring in the soft tread of Pilot Sport 4S tires and yeah you go through tires pretty quickly compared to "normal" cars
