Question regarding Extended Warranty
Wheel & Tire - 3,475
4 year extended warranty - 5,575
Prepaid Maintenance - 2475
Anyone know if this is reasonable? I’m assuming everything’s a bit higher since its an AMG but any information or perspectives would be great.
Also, I read I could have bought these items from any Mercedes dealer. I wish I knew that but one thing I’d like to know is if it is still possible to do so. If I can cancel this warranty/add on’s through the dealer which I purchased through if I say find better pricing at any other MB dealers in the US.
the prepaid - how many years or services?
the extended warranty - same advice - you can just pocket the cash and pay as you go, chances are same you'll not need it in your ownership or the real costs of ownership will be in the years beyond the extended warranty term
I paid approx $3400 for an extra 2 years of CPO coverage from Mercedes
I do not believe the maintenance is discounted anywhere. Someone correct me if I am wrong on this
Service A and B alternate with A costing around $300-$500, and B costing around $400-$800. The only difference between the two services is that B adds the engine compartment cabin dust filter replacement and a brake fluid change. If these were the only service requirements, Star Prepaid Maintenance would be grossly overpriced.
The Mercedes Overview for Service Sheet dated 10/03/2022 (AP00.20-P-1240XA) adds the following required maintenance:
Service 8 every 30,000 mi/3 years
- Engine compartment : Replace air filter element.
- Rear axle: Change oil.
- Replace spark plugs.
- Automatic transmission: Change oil and oil filter.
- Transfer case: Change oil.
I recently purchased the 3-year pre-paid maintenance and have just had the 30,000 mile required maintenance done. Had I elected to pay for this service, it would have cost me over $2,000 - I do live in the Tri-State area so dealer pricing is at the top end. My 40,000 mile service would have cost me around $700 and the 50,000 mile service with the spark plug replacement and transfer case oil change would be in the ballpark of $2,500. Purchasing Star Prepaid Maintenance is probably going to save me around $2,000 if not more as service pricing seems to go up every year.
Regarding where to purchase Star Prepaid Maintenance, I did some Internet research, called around and ultimately purchased from: Jeff Jackson atMercedes-Benz of Louisvllle - 502-894-6829.
If this maintenance was done by an independent shop the numbers would change and Star Prepaid Maintenance may not be cost-effective. That said, I suspect it would not be significantly cheaper, at least where I am located.
I have the 20 inch AMG wheels which are known to damage easily. I cracked a wheel last year and only paid $250 to have it fixed. Wheel/Tire warranty not worth the cost.
