W213 Engine Warning Light Question
Old Mar 11, 2024 | 09:49 AM
SunnyDublin's Avatar
c207
Hi,
Any help with this is appreciated.
I recently bought a W213 Coupe. All running fine but then an orange (solid not flashing) warning light came up. The first time this happened it disappeared after I restarted the car. The second time it stayed for 4 or 5 restarts. I wanted to test something so I filled the car to the brim with diesel. I started the car again and the warning was there but I drove for a few miles and restarted and the light disappeared again.
There is no sense that the car has any problems. The car doesn't go into limp mode etc.
Any thoughts on what the likely trouble is?
Old Mar 11, 2024 | 11:29 AM
bobblehead's Avatar
go fast grocery getter wagon
early sign of a possible coils issue. Bring your car into your shop or dealer to have it checked out.
Old Mar 11, 2024 | 12:34 PM
streborx's Avatar
Top Answer: 1
G550
Originally Posted by SunnyDublin
Hi,
Maybe the fill-up has nothing to do with it, but most manufacturers instruct you not to fill the fuel tank up to the brim (which I take to mean the fill cap). My understanding is that there can be vent line connections in the filler neck, and if these get filled with fuel, you can end up with major headaches. When the fuel dispenser nozzle clicks, quit pumping.
Old Mar 11, 2024 | 01:36 PM
superswiss's Avatar
2019 C63CS
It sounds like you are in the wrong forum. This one is for the AMG variants. AMGs don't run on diesel. Anyway, a solid CEL is typically something emissions related and can be as simple as the fuel cap being loose or leaking. You have to connect an OBDII diagnostics tool to read out the actual error codes to know why the light came on.
Old Mar 11, 2024 | 06:42 PM
c207
Thank you. I will do. I wanted to see if someone had this exact problem though. It is under warranty so I will definitely check it out.
Old Mar 11, 2024 | 06:43 PM
c207
Sorry, to the brim meant to the nozzle click.
Old Mar 11, 2024 | 07:00 PM
c207
Sorry, it is AMG-Line. My mistake.
I was hoping someone would say definitively it was something simple based on my story. I will have the diagnostics run.
As the warning has now cleared off the dash will the error code still be saved when they run the diagnostic?
Old Mar 11, 2024 | 08:40 PM
atl 2 chi's Avatar
Current :2018 E63S and a 2018 GLE 63S . Prior, CLA 250, C450, 2017 AMG C63S
Sounds like coil issues. Had the same issue. Engine was misfiring. All coils have been replaced but one. Luckily, they have been replaced under warranty.
Old Mar 11, 2024 | 09:56 PM
taphil's Avatar
2024 GLE63s, 2021 E63s, 2018 GLC43
Do diesel engines have coil packs?
Old Mar 11, 2024 | 10:57 PM
superswiss's Avatar
2019 C63CS
No, they don't. Diesel engines ignite the fuel using compression heat, not spark plugs. This thread is in the wrong forum as said.
