[w213] Complete Air Balance Retrofit Guide
Old Aug 6, 2024 | 10:21 PM
deadcat's Avatar
AMG GT53
Recently wrapped up an Air Balance retrofit and decided to create a detailed guide for the community (see attachment). Everything's working perfectly now: the fragrance falcon pops out when you open the glove box, the screen alerts you if you remove it, you can adjust all the settings, and you get that nice scent when you start the car. Since I struggled to find good info during my install, especially for wiring and finding the fragrance hole, I figured I'd write up a guide for others taking on this project. I did this on my x290, but it should work the same for w213, w222, and x253 models, so sharing in these sub-forums as well. Enjoy
File Type: pdf
Old Oct 23, 2024 | 06:52 PM
sweetnsassy's Avatar
2024 CLE-53 AMG
Where are you located?
That’s impressive. I just got my new CLE53 and it doesn’t have the option P53. Where are you located? Would you like to install it for me if I buy the OEM kit?
Old Nov 7, 2024 | 08:37 AM
AT2018MB's Avatar
Hi! just wonder, if i buy this 2 components SH from a wrecked car, can i still proceed with the retrofit and with the coding? i mean, will it still works? thx
A2238351600
A2228900100
Old Nov 26, 2024 | 11:16 AM
haseeb 224's Avatar
Hello
Is it possible to fit this system in w212?
Old Nov 26, 2024 | 01:30 PM
deadcat's Avatar
AMG GT53
Thanks, I don't really like doing this kind of stuff unless it's on my own but I'm guessing you can bring the guide to a shop that works on Mercedes and they can do it. They might not even need the guide, depending on their experience with retrofits and wiring.
A2238351600
A2228900100
They should, unless they were damaged in the accident, which I doubt.
Originally Posted by haseeb 224
Hello
Not entirely sure.. if the 212 is just the same thing as a 213 but station wagon, then I would assume the front parts are the same. If you look in your dash and start seeing a bunch of parts labeled 213 then odds are even better. Really you just want to make sure the LIN wire is the same, if so then it'd work.
Old Nov 27, 2024 | 05:45 PM
AT2018MB's Avatar
Thumbs up
Hi
thnaks! do they need to be virginized, like the weidescreen when yo do retrofit, or just plug an play and coding?
Old Nov 27, 2024 | 06:47 PM
trigital's Avatar
W213 All-terrain
Hi
Those are missing any security, it can be installed without any issues.
Old Nov 27, 2024 | 07:30 PM
deadcat's Avatar
AMG GT53
This is correct. You just hook it up, code it and you're good. You could perform a teach-in in Xentry if you want. I did, eventually after a few months when I was in there anyways. It did nothing lol. I mean, I can actuate it in Xentry now if I want, but other than for diagnosis purposes like actuating or utilizing features in Xentry.. a simple plug and play will work just fine.
Old Nov 29, 2024 | 04:45 AM
Aussie_E350_Wag's Avatar
2013 E350 Facelift (Japan Import) 2007 E350 Elegance Wagon, 2014 E350 Wagon facelift model Jap Model
I have this in my glove box but the bottle is missing, can you buy replacement bottles do you know?
Old Apr 1, 2026 | 01:25 PM
Dachi's Avatar
C450
hello, do I have to buy retrofit kit? or I can take system from car which already has air balance and transfer to mine
Old Apr 1, 2026 | 01:57 PM
deadcat's Avatar
AMG GT53
You can buy them on Amazon, search for Boxiti
No, if you have the parts that's all you need, then have to update the HVAC ECU settings as well the way the guide mentions.
Old Apr 2, 2026 | 11:46 AM
Dachi's Avatar
C450
Okay, so, i dont need to buy pre made kit, it is already plug and play? do i need to change glove box also?
