S & CL = CLS wheel?
Old Apr 8, 2005 | 07:06 PM
hlkc's Avatar
06 CLS500 + 99 ML320
S & CL = CLS wheel?
Is S and CL wheels same as CLS wheel?
Thanks,
hlkc
Old Apr 8, 2005 | 11:31 PM
Harris's Avatar
Thanks,
hlkc
No, CLS has much lower offsets than S and CL.
Old Apr 11, 2005 | 12:36 PM
hlkc's Avatar
Harris,
Is the all around or just front? So MB and other tuners makes the wheels just for CLS?
Thanks,
hlkc
Old Apr 12, 2005 | 01:57 PM
Harris's Avatar
Harris,
Thanks,
hlkc
All around.
The CLS shares the same wheel fitment as the SL.
Old Apr 12, 2005 | 02:01 PM
hlkc's Avatar
All around.
Harris,
Any idea about the bolt size? Do you know CLS uses 12 or 14mm bolt?
Thanks in advance,
hlkc
Old Apr 12, 2005 | 02:28 PM
Harris's Avatar
Harris,
Thanks in advance,
hlkc
14mm.
Old Apr 12, 2005 | 03:17 PM
hlkc's Avatar
14mm.
hmm I spoke with few people and they all told me is 12mm... Can you confirm that? Did you install 14mm to CLS before? Please advice.
Thanks in million,
hlkc
Old Apr 12, 2005 | 03:41 PM
Harris's Avatar
Thanks in million,
hlkc
You should have spoken to me first! No, I have not installed any wheels on a CLS yet because it has just been released a month ago. BUT, my Brabus catalog shows they use 14mm bolts on the CLS. The W211 uses 14mm as well (W211 and W219 share the same chassis).
Old Apr 12, 2005 | 03:55 PM
hlkc's Avatar
Harris,
I thought W211 uses 12mm??? If W211 uses 14mm then I think CLS should use 14mm too. How can I find out for sure? I called the dealer and they said they don't know...
Old Apr 12, 2005 | 05:00 PM
hlkc's Avatar
Harris,
Brabus and you are correct. Yes, It's 14mm. I just took a bolt out and bought it to a tire shop and they have a 14mm nut and screw right in.
Thanks,
hlkc
Old Apr 13, 2005 | 09:29 AM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
w211 = 14mm ..... you should have just searched here it's been discussed quite often
Old Apr 16, 2005 | 09:43 AM
aniantchev's Avatar
2007 ML 320CDI
In plain English, does that mean that any wheel from a SL will also fit the CLS?
Old Apr 16, 2005 | 05:11 PM
paul928's Avatar
04 E 500 4matic wagon; CLS 63 AMG
Does anyone know when Tire Rack is planning onposting alpproved wheels for the CLS 55? It has them for the CLS 500 but not the 55.
Old Apr 19, 2005 | 11:40 AM
velgdanban's Avatar
Thanks,
hlkc
No, the wheels from CL and S is not the same to the CLS.
The CLS has lower offset which gives deeper lip on a multi piece wheel.
the CLS shares the same fitment with SL
more info in www.permaisuri.com
Last edited by velgdanban; Apr 19, 2005 at 11:43 AM. Reason: want to add up more info
Old Apr 19, 2005 | 11:46 AM
velgdanban's Avatar
YES... you can use up to 20" with 245/30-20 and 285/25-20
