Patching Wheel
My initial thoughts are to break the bead, line the inside with duct tape, put a small wheel weight into the opening, to compensate for the missing metal mass, then cover the outside with duct tape, creating a duct tape sandwich.
As it stands now, it does not hold air.
Seriously, whatever put the hole in the wheel will have stressed the metal around it...that's known as fatigue, which forms the basis for complete failure later on.
You can patch tires, but not wheels. You have a hole in a wheel? Then you have a large doorstop, a base for an end table (hey, a round sheet of glass and it's perfect!) or a small boat anchor, but what you do not have is a wheel.
Even if you could patch it so it would hold air -- and duct tape won't do that -- would you entrust your life and the lives of those you love to save a few hundred bucks (and much less than that if you find it used on line)?
On the other hand, some of us would say 'hey, this is the EXACT excuse I need to buy TWO new larger wheels of the same design and go for the staggered effect!' (Or buy four larger of a different design and upsize your ride!).
Simply put: don't use this wheel again -- please.
But do enjoy your ride, even on the spare.
Greg
Tires are designed to be flexible, wheels are not. Face it: there is NO SAFE FIX for that wheel. You're asking for catastrophic failure and if it's at speed when it occurs, for shrapnel to be flying about as the wheel comes apart.
If you're really serious -- and this wasn't a "joke post" -- then patch it however you want, but give us the opportunity to buy some life insurance on you before you drive it.
Add a bunch of unsprung weight.
Further degrade the tire's performance due to no longer having air pressure supporting the tire carcass as designed.
A free ticket for what could be (we hope!) the last ride of your life when the rim fails completely,which it will.
Ever hear of crack propagation?.You can see one in the picture, and it's got several friends to assist it in finishing the job.
If you insist on going the "repair" route, please be sure to have the entire family with you whenever you drive on that wheel...the gene pool will be better after a purge of your tribe's idiocy.
Yes, it is possible to envision the widespread carnage and genetic cleansing from operating a vehicle using this tire filler within the Manufacturer’s rated 35 mph limitation. It is likely to be on par with your bicycle collisions with cell phone pedestrians.
