210 Rims On 211
spoke to Luke and he told me of the 12mm vs 14mm issue
has anyone tackled this and if so what is entailed to make the rims work.
I have done a number of searches on this site and only find rims from 211 being use on 210 applications.
any help would be appreciated.
dr dave
The problem was 211 wheels on 210 cars. I special ordered a set of large ball seat 12mm bolts from Motorsport to mount these on my 210 and all is fine.
Are the GT3s oem Mercedes ball seat style? Let me know if you need the lugs. I will check what length I have. Check to see what you need. Thanks
at this point, I could have the holes machined out so the 14 mm bolts would fit in and then if I bought the 12mm headed bolts from driver 55, then the rims would work?
dr dave
Theoretically, if it's done by a competent machinist it should work, you're talking about very little material to be removed. I think the issue is that as you remove material you're encroaching on the ball seat. Were it mine I'd take one wheel and a lug bolt to a machine shop and ask them unless you happen upon someone on the forum who's done pretty much what you're asking about.
Good luck and post back up! Enjoy the ride,
Greg
on the my ssr's the hole is 15mm across and the existing lugs from my w210 e55 are 12mm (actually a hair smaller).
this is encouraging. when I get the new car next week, I will be able to pull the lug off and see if it wil make it thru the hole.
if I do need to machine, it won't be too much.
now, where do I buy 14mm lugs with "12mm" heads?
dr dave
211e500
amg sport, pano, ent, lighting
was able to buy 14mm conical lugs...they dropped in the holes for my ssr rims with no problems.
will be bolting up the rims on tues night when I get the car.
will keep you all posted.
dr dave
e500
amg sport
pano
lighting
ent
soon to come ssr rims
