Better handling from 17's vs 16's?
Old Sep 7, 2005 | 06:32 PM
CE750's Avatar
'05 E320 CDI, '08 BMW X5 4.8i, '11 Duramax 2500HD
Should I expect "noticeably" better handling from my W211 (non-DC) when I go from 16" OEM Rim w/ 225/55 to 17" OEM Rim w/ 245/45's?
thanks
Old Sep 7, 2005 | 06:55 PM
E55AMG99's Avatar
1951 Caterpiller D6
With the same type of tires, your handling should benefit from the shorter sidewalls. Your ride will suffer, however. Also, if the new rims and tires are heavier, handling, accelleration and braking will suffer. It will be worse with a light rim/heavy tire combo of a given weight.
Old Sep 7, 2005 | 09:42 PM
CE750's Avatar
They'll be Michelin's, but performance, rather than the all-season's that I have now.. so the rubber will be better..
I'm not worried about ride, as the current ride is very good, and I can stand giving up some of that for a better cornering.
I read the W211 E320 has a .83 200' skid pad.. but I've also read that certain tests have yielded .85g.. so I wonder if that's due to 16" vs 17" cars.
Old Sep 7, 2005 | 09:46 PM
vraa's Avatar
With 17's your ride quality won't be that harsh.
Getting wider rims (or even larger diameter) rims, will greatly improve your handling, everything will seem sharper.
On top of that, by moving to Michelin Performance tires (I hope you mean the PS2) you'll have so much grip, you don't know what to do with it.
Seriously, you'll have grip
Old Sep 7, 2005 | 09:48 PM
CE750's Avatar
Wow, I can't wait now! I think their Pilots (but not sure which models) they're stock on the Appearance package E350/E500's.. what ever those are.
Can't wait!
Old Sep 7, 2005 | 09:51 PM
vraa's Avatar
Try to make sure that they are PS2's. So many people have them and truly swear by it.
Old Sep 7, 2005 | 09:52 PM
CE750's Avatar
They're Pilot MXM4 what ever those are..
Old Sep 7, 2005 | 09:54 PM
CE750's Avatar
I don't think they are "Hi performance" but they're still better than the Energy M's I had on before.
Old Sep 7, 2005 | 09:57 PM
vraa's Avatar
Watch out for wet traction. I had those on my LS400 before and I slid.
Old Sep 7, 2005 | 09:59 PM
CE750's Avatar
Tire rack doesn't like their snow traction at all, but gives them good dry traction.. I think I'll heed your warning.. My next set (when there wear down) will be a set of "true" high performance like the PS2 you mentioned.
Old Sep 7, 2005 | 10:05 PM
E55AMG99's Avatar
1951 Caterpiller D6
My guess is that the difference between .83 and .85 is as much due to the different test tracks, drivers and methods as it is the different tires that MB OEMs. In other words, too close to call.
