caliper paint..
1 Post
C230 Kompressor (02 Copupe)
caliper paint..
I been looking trought the shops near my town for Red Caliper Paint, specially for G2 or Telia somehting, forgot the name.
Some guys at a shop recommended me to just use the spray paint they sell at pep boys and ****, the engine paint. We are gonna use it for my car and a S4, what do you guys know about it?
Its like 30 dollars cheapers, so whatcha guys think?
W203 coupe Kompresor
i'm paying for a friend to do mine at his shop.. gonna do a few of my friend's calipers too! cuz we are gonna BAKE the paint in just like when u paint the body.. if u spray it's gonna come off and look like shiet....
just use high temp paint. i haven't heard of anyone having problems with this method (including myself).
just don't spray it. use a brush and a few coats. for the last coat, you may want to spray it for a smoother finish.
Former Vendor of MBWorld
i used the G2 paint for mine and it looks just like it was powder coated on.
If it was me i would not use any of that spray paint. It wont look as good, last as long, or give the same protectin against the dirt or brake dust.
heres a pic of mine.
The kits by www.G2usa.com, www.Foliatec.com and www.Legend5.com all come with a chemical hardender. The spray on stuff does not. You can put 4-5 coats with the brush on stuff.
I just used G2 in blue on my E55 and added red to my Sport Trac. I have done this procedure 4 times and I like to remove the pads.
C240/6 Megma Red
The spray paint is OK. It give me a high grossy look and last me for more than 5 years. I use VHT hi temp rate 900F. They even have a picture of brake caliper on the can. The trick is you need to clean the caliper real good. I use brake cleaner spray and a wire brush then I paint it 4-5 coated. Make sure you let the paint dry between each coat. Don't forget to cover all the area that you don't want to paint it. I did touch up spray every 1.5-2 year to give it a fresh look.
Oh it's about $8 a can
Hope that help
Zpeed
Hope that help
Zpeed
1 Post
2007 GL450 2010 GL550 2020 Sprinter 4x4
I just picked up some of the G2 caliper paint. I am going to try it out this weekend on my wife's ML. To those that have used it, how quickly does it dry. If I jack up the front of the car, remove the wheels and paint the calipers, will I have time to then jack up the back before the paint sets? Would it be better to just remove all 4 wheels at once?
Thanks - John
Thanks - John
Thanks - John
Thanks - John
goodluck.
1 Post
Thanks BlackC230coupe. Time doesn't sound like it is an issue. I think I'll just lift & remove 2 wheels at a time. If I have enough left over after doing my wife's truck, maybe I'll do up my car.
-John
-John
pep boys.
kragen has them also. it is just regular high temperature spray paint that i brushed on.
they have silver and black also. make sure you clean your calipers well before you paint and put on a few coats.
1 Post
Well, I spent a bit of yesterday working on my calipers. I am very happy with how they look. BUT, I got ****y and decided to do both cars. Yes, the G2 kit includes plenty of paint, but time was not on my side. I painted 5 of 8 calipers before the chemical reaction in the paint took over and I had a can of red blobby goo.
Instead of picking life & limb picking up more paint in the "nice" part of town again, i am going to order more online and will finish the project when it shows.
Here are some pics of the project so far...
1 Post
Finally, the final effect on my car. And yes, I have only one red caliper on my C240 until I get more paint . Overall, I am very happy with the outcome and look of the project. While adding zero hp, my braking distance is greatly improved .
BTW, is there any way of taking it off if you didn't like the outcome?
1 Post
Originally posted by wants a cCoupe
so, let me get this stright.
when u guys paint your caliper, u guys don't remove the caliper it self from the rotor and pads. U guys just paint what ever area u can reach ?
