Bolt Size
The tyre shop recommended drilling out the wheels and putting a 12mm 45 degree taper inserts into the wheels.
Any recomendations? Please help!
if i'm understanding this, you have car with 12mm diameter bolt.....and am
guessing the bolt has (X) taper/cone seat. you have wheels from later model,
which uses 14mm dia. bolt with (Y) taper/cone seat. if so, contact OTISINC
to see if they have proper conversion bolt you need.
what i did....
I will try a couple local MB specialists first.
Does anyone in Australia stock these bolts?
to you down under would add another $40-50....so the total would be a little
over $100 US. still cheaper than custom bolts if they charged $5. i've seen
higher price for custom.
larger cars run the 14mm radius seat with the 14mm diameter bolt and smaller/lighter cars run a 12mm radius seat and 12mm diamter bolt
W211.
