Weird Tire Wear E500
I didn't mention the name of the tires because I don't want to give bad press when any company can make a bad tire.
Thanks Jim
At least it does drive straight now. Interesting item I found on the conti website. Their description of the factory tire was no seams in the web of the tire. Can't help but wonder if that has something to do with these tires wearing on the edges. Also Michelin surveys indicate they wear even and have low noise also. I was shopping on TR for replacments but plan to use only OE replacement tires to get back to base. But for now the edges both inside and outside of the front tires are wearing at 32 psi and when the tires roll slowly almost you can actually feel the bumping of both front tires. This noise bumping was there when the tires were new, but not present with the origional conti's. Jim
