Will C32 Wheels Fit on a E55?
Old Aug 5, 2008 | 09:28 PM
joesc230's Avatar
2002 C230 Kompressor
Hi all,
I have HRE wheels that fit a C32 AMG. I am selling them and the guy that wants to buy them has a E55. Does anyone know if they will fit? I'm not sure of the offset and bolt pattern needed for the E55, and don't know what the C32's typical offset and bolt pattern are (since that is what the HREs were made for)...anyone know??
Thanks a lot!
Old Aug 7, 2008 | 09:39 AM
joesc230's Avatar
Anyone??
I'd really appreciate some info!! Thanks!
Old Aug 7, 2008 | 04:35 PM
gswc32's Avatar
C32, C55, C63,Clk550, E63 RennTech Tuned
They might. See the attached application guide for Mandrus wheels. Since HRE are custom, you need to know the offsets.
Old Aug 8, 2008 | 01:56 PM
lkchris's Avatar
'10 CL550, '12 GL550
It's pretty likely your C-class uses 12 mm wheel bolts.
For sure the W211 uses 14 mm wheel bolts. This means the bolts he needs won't go through the wheels.
Of course if you're talking about a W210, then that's different but then you didn't specify, did you?
Old Aug 18, 2008 | 06:11 PM
Hokie1200's Avatar
2004 C230 Kompressor Sport sedan 6 speed manual, 2013 S550 Sport 20" AMG
I am currently pulling my hair out trying to get HRE's made for a C240 to fit on a C230 Sport (front caliper clearance, spacer, lugbolts). I am pretty sure the lugbolts for C, CLK, and SLK are 12x1.5 while the E and larger classes use 14x1.5. I am sure both cars have large AMG calipers, but are the E55's larger? Guess my opinion is the C32 wheels would not be recommended on an E55.
Old Aug 19, 2008 | 12:18 PM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
and the C32 wheel would not have the proper load capacity for the E55
