What Really Happens W/O Tire Sensors - C Class
Old Dec 15, 2008 | 11:30 AM
Mark08859's Avatar
2008 C300 Sport
There have been a number of posts, on this and other forums, questioning what happens when a person puts on wheels (usually for winter) w/o a tire sensor. I can relate what happened on my 2008 C-Class when I switched to winter wheels/tires. It is a U.S. version with a manual transmission.
When I initially drove away from the tire place, nothing happened. I had been expecting the flashing red display or some sort of audible alarm. None of this ocurred. After about 10-15 minutes of driving, a messge appeared in the center of my message center advising that the TPMS was inactive. I simply pressed the "OK" button on the left steering wheel control and the message went away. I had my normal display back with the usual functionality.
The only other thing is a warning light in the tachometer region of my display. Near the 5000 rpm marker is a tire icon (a cutaway view) with an explanantion point ("!") within the tire. It started out flashing then became a steady display. It is easy to ignore.
During this past weekend, that scenario repeated itself after every start. Based on that, it was no problem driving without a monitor in the wheels.
Old Dec 15, 2008 | 04:25 PM
lkchris's Avatar
'10 CL550, '12 GL550
So, your message is it's ok for you and your family to do without a useful safety feature.
Yet another in the infinite number of rationalizations that it's ok to be cheap.
Kar don's Avatar
Mercedes-Benz
Yeah I'd like to know as well... I will be doing the same thing in my 08 CLS550 this week.
Old Dec 16, 2008 | 09:31 AM
Mark08859's Avatar
2008 C300 Sport
A. It's called a tire gauge. Most folks know how to use one. I suggest you check one out. Honest, they're not diffucult to use.
B. If you have sudden deflation, you don't need a TPMS system, the sudden change in handling will be enough for most alert people.
Old Dec 16, 2008 | 05:58 PM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
good info!!!
Old Dec 16, 2008 | 06:41 PM
Kar don's Avatar
Mercedes-Benz
same thing happened to me today. No light after driving away then sure enough 5 min later it said no sensors detected tire pressure inactive and the orange light started flashing. It stayed flashing for a while then went solid. Had it stayed flashing I probably would have went and installed sensors lol.
Old Dec 17, 2008 | 09:58 AM
Mark08859's Avatar
2008 C300 Sport
I think I could tolerate the constant flashing of that icon. If there had been a constant audible alarm, that would be cause for rethinking the sensors.
Old Dec 17, 2008 | 10:49 AM
Abel1337's Avatar
E63
I work at mercedes and this seems to be the number one problem of people with newer models. It is an easy fix, just take it in and they will ususally do it included in with your normal service charge
Old Dec 18, 2008 | 09:27 AM
Boulder GT3's Avatar
E320 CDI, SL550, clk550
I hate TPMS. It's the cure for an illness I never had. It's a fine option for the numb crowd that can't watch tire pressure but there should be the capability to turn it off.
Old Dec 22, 2008 | 07:03 PM
delirium's Avatar
C350
this is good to know for temporary winter usage, thanks!
Old Dec 22, 2008 | 07:43 PM
lkchris's Avatar
Your post is either absurd or not an answer to the question posted here.
The liability to a dealer for turning off a safety feature could be staggering.
I frankly don't believe you can do it.
Old Dec 22, 2008 | 07:45 PM
lkchris's Avatar
Now there's a dumb statement.
What if sudden deflation is caused by low tire pressure? Wouldn't you like to know before it happens? What if your "sudden change in handling" puts you on your roof?
Old Dec 23, 2008 | 02:40 PM
Hey hothead, I think he meant to just reset the system.
Old Dec 25, 2008 | 03:27 AM
ch4rlie's Avatar
SL 500
you dont need them its really just on there because its a luxury car
Old Dec 28, 2008 | 05:06 PM
AMGTestDriverNJ's Avatar
86 190E 2.3-16v, 92 500E, 03 CL55 AMG, 08 E3504M Brabus
Ha, well put. Its really not a big deal to not have the sensors in there. I do it alot as I switch wheels and tires more often than shoes. It cost extra to take tires off and remove sensors and move them around I just don't bother most of the time. Especially considering that TPMS (atleast on the C class) doesn't let you know there is any issue until your holding less than 25 psi anyhow which at that point if you can't tell from driving/looking at it then you should probably brush up on your handyman garage skills a bit. There is also no reason people shouldn't check their tire pressure atleast once a month with a tire gauge, they are free at most tire places anyhow. I really don't think it has anything to do with whether you are cheap or not. Those sensors are like 60 bucks a piece and do next to nothing. I could see if they gave digitial read outs at all four corners like some other Benz models do, but not the C anyway, or the E for that matter. My CL doesn't even read out at all four corners.
Old Dec 30, 2008 | 04:20 PM
Bobby204's Avatar
2001 R129 SL500, '08-'20 W204 C350
Second that, when you have winter tires without sensors, IMHO it's okay to deactivate pressure monitoring. Reactivate pressure mointoring when regular tires are back on.
BTW, anyone else got tire pressure warning because it got really cold outside? Tires are okay, just 2-3 psi short due to temp change.
Old Jan 1, 2009 | 03:13 PM
polarbexar's Avatar
Veteran: Air Force
2025 Mazda CX70 Turbo S, 2015 G550
Pretty much all cars in U.S. have to have them. Remember Ford and Firestone? Laws are made because of lawsuits.
Old Jan 7, 2009 | 05:14 PM
Mark08859's Avatar
2008 C300 Sport
Please, enough of this. Low tire pressure is a gradual process. Hence, the tire gauge. If something is so drastic as to put you on your roof, then a TPMS will be of no use to you.
Old Jan 25, 2009 | 10:25 AM
benz rider's Avatar
would deactivating them void any warranty you might have if you end up crashing the car due to low pressure?
I don't have them on my C but the thought of a benz hauling *** on the highway and hitting a bump causing a forced release in pressure might be tragic if your system didn't warn of you what just happened.
and I agree with the air guage advice. it's only right that if you love your car to have one or two of these things within reach.
