wheels, i need knew ones
Old Jan 26, 2003 | 05:34 PM
pitbullforte's Avatar
mercedes clk 200 kompressor 2000
this is my first post . i got a mercedes clk 200 kompressor 192bhp. i want 19" so could you give sizes of tires,etc...
thank you
i am from portugal
Old Jan 26, 2003 | 05:46 PM
Petie's Avatar
2000 CLK430
tire sizes can vary depending on the width of your wheels and if you go with a staggered setup. make sure your wheels are the correct offset for your car. that being said, i have 8 inch rims in the front and 9 inch rims in the rear, some have gone wider, but the tire sizes for those rims would be:
front : 225/35/19 or 235/35/19
rear : 255/30/19 or 265/30/19
Old Jan 26, 2003 | 05:47 PM
Adonis's Avatar
CLK 320
Without modifying your car 19x8.5 front 19x9.5 rear should be the ideal wheel size and 235/35/19 front 265/30/19 rear should be the ideal tire size. This does vary from type of wheel to type of tire so check with an xpert.
Old Jan 26, 2003 | 05:56 PM
LowRydeR's Avatar
I second that, I had those on my old 19" Brabus and new wheels too.
-Bruce
Old Jan 27, 2003 | 03:09 AM
henry47's Avatar
asdf
Bleh, too bad I can't run 265/30/19 anymore. I'm running 19x9.5" in the rear and on 245/30/19. Believe me, my shop TRIED to fit anything wider, but it kept on rubbing against the fender and the gas canister. Oh well, it's safer this way.
Old Jan 27, 2003 | 07:34 PM
theine's Avatar
2014 GLK250 BlueTec & 2009 ML320 BlueTec
Have they rolled your fenders?
Old Jan 27, 2003 | 10:58 PM
henry47's Avatar
asdf
yeah, they rolled to the max. The rear's are rolled a lot but it turns out that it wasnt the fender that was rubbing but the rear bumper underneath the fender.
Old Jan 28, 2003 | 07:37 AM
theine's Avatar
You need spacers to get the proper offset.
Old Jan 30, 2003 | 07:07 AM
CLk BoOst's Avatar
1999 CLk320
19z and push it all the way out to the fender
