Rims and Vehicle Questions - '03 CLK 500
Old Jul 22, 2009 | 09:12 AM
Rwhjr3's Avatar
2003 Mercedes CLK 500
Hey everyone, I have a 2003 CLK 500 and was given a set of 20" Lowenhart LT5's. The rims were originally on a S 55 AMG. Does anyone know if these rims will fit on a CLK 500, or if it needs spacers or adjustments to get it to fit? Everywhere I looked doesn't have these wheels listed for the CLK model, only S and CLS. Does it mean it's still not possible to get it work correctly?
Thanks for any responses.
Old Jul 22, 2009 | 10:06 AM
sweet jones's Avatar
W209, E46 M3 (dead), S54 swapped E46 Touring
yes they should fit. just put them on. i doubt you will have a problem with fitment. the sizes are not that much different than stock to where it would rub or not clear brakes.
Old Jul 22, 2009 | 10:52 AM
Rwhjr3's Avatar
Ok, thanks for the response. I started putting them on and ran into a problem. When I put the front wheel on, the shocks/spring is in the way and the tire won't go on. I would need the spring to be up another inch or so for the tire to clear. Any suggestions on how to handle this?
Old Jul 22, 2009 | 12:04 PM
would you happen to know the offset on the front wheels?
Old Jul 22, 2009 | 12:07 PM
$tallion's Avatar
97 C28
gIVEN lolol
Old Jul 22, 2009 | 12:32 PM
kiamcoj's Avatar
2012 CLS63
That's one of the issues running 20's, you need to ensure that the offsets are perfect and run smaller tires. 20's and CLS' run bigger tires than a CLK can.
Sweet Jones, where are you getting your fitment information from? Just off the bat, there are some modifications that need to be done to get S/CLS class wheels to be interchangeable with CLK's, so how did you know they would fit or wouldn't run into a problem without tire sizes and offset information?
Old Jul 22, 2009 | 01:57 PM
Rwhjr3's Avatar
Originally Posted by $tallion
gIVEN lolol
and the joke is...?
Don't respond unless you're going to actually contribute to this thread or help with my questions.
Old Jul 23, 2009 | 10:52 AM
because most or the majority of mercedes benz wheels offsets are about roughly the same all around it shouldnt be hard to fit. you guys make a huge deal about 10mm which is hardly nothing at all.
10mm = .39in
with a lot of people running weak wheels and ugly gaps its possible to fit most oem wheels from car to car. unless you plan on dumping the car to the floor i dont see why threy would not fit. offset and tire size are the biggest factors just like you said in your post above.
i have a lot of experience with aggressive wheel fitment on quite a few different types of vehicles except mercedes but the idea is the same.
