Which is worse? (Spring Question)
Old Feb 20, 2003 | 10:56 AM
Limited Edition 190E's Avatar
2005 CL65 AMG
Which is worse?
Heating a set of linear-rate springs or cutting a coil off a set of linear-rate springs?
Thanks for you input,
Don
Old Feb 20, 2003 | 12:10 PM
otoupalik's Avatar
MBWorld Founder
Heating is worse, BUT, they are both VERY BAD solutions. Springs are engineered to be the size and shape they are. Cut or heated springs may give you the look you want, but the ride will suffer and could lead to failure of the spring, shock, etc.
Brad
Old Feb 20, 2003 | 01:27 PM
Timster's Avatar
2011 GL450
OMG! Please don't do either. The amount of money you save by not buying springs will cost you 10X to fix all the damage that would will done.
If you heat the spring they lose there tension strength and continue to sag until there's no spring left.
Cutting the spring as Brad said is not a good idea either.
Regards,
Tim
Old Feb 20, 2003 | 04:29 PM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
NO TO BOTH !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!
Old Feb 20, 2003 | 05:20 PM
otoupalik's Avatar
MBWorld Founder
Luke,
I am sure he will think we are just saying this to sell H&R's! LOL
Brad
Old Feb 20, 2003 | 06:17 PM
KWiK's Avatar
2002 C230 : 2007 C230
Originally posted by otoupalik
Luke,
Brad
I don't sell anything so ,
Don't Do Either!
Old Feb 20, 2003 | 09:15 PM
2005 CL65 AMG
So how do you all really feel? :p Thanks for your input...You pretty much confirmed by suspicions.
