Questions for Luke - Tirerack
I have a 2001 Mercedes C240...could you please help me with the following questions before I buy all the parts from Tirerack:
1. Springs: is the car comes with spring pads like the old C-class?
2. For Eibach Pro Kit...do I have to change the shocks as well? Also, will the wheel alignment specs will be different than the stock setting?
3. For street use, do you recommend Eibach or H&R springs? I do not want harsh ride.
4. For AMG wheels...which size do you recommend 17" or 18"?
Your assistance is greatly appreciated.
Hi Luke,
No, your car only has rear spring pads, Dot 1-Dot 4. Dot 1 is 8mm thick, they go by every 5mm increments, Dot 4 is 23mm.
Yes or no. IF a set of stock shocks will last 5 years, getting the springs alone will only shorten the life expectancy by 1 year. Really depends if you want to improve the handling a lot or not. Its okay if you dont get the shocks.
It is recommended to adjust the alignment everytime you change the suspension on your car.
Eibach is more comfortable, but will not lower your car as much. H&R will lower a bit more and have a slightly rougher ride. Again, depends on whether you want a more aggressive look or not.
17" will definitely be smoother. 18" will look nicer but a bit rougher, and also depends on your budget.
Thanks [/B]
I'll give you an "A" not an "A+" ....here's why ...you miss read 1 question ....
Also, I would recommend that you change the shocks as well because the progessive nature of performance lowering springs will make the shocks wear faster and since the suspension is already apart change them .... rather than paying a second labor bill to change them in the near future
Thank you guys for the reply...I appreciate it.
Another one Luke, If I buy the 17" AMG wheels, can I use the factory lug nuts?
Yes, you can!
would new lugs only be needed mostly when you get wider wheels? ex: stock 8.5 you put 9.5 need new lugs? but if stock 8.5 and keep 8.5 but bigger wheels as from 17 to 18 etc would be same lugs?
thnx in advance
