Sway Bar recommendation for 01 E430
Old Apr 6, 2003 | 11:36 PM
Richard Galing's Avatar
W210, W220, W163, W164, C6
Can anyone provide some recommendation on sway bar upgrades on my 2001 E430.
My set-up consists of:
Brabus springs (1) coil cut
OEM shocks
What should I expect with upgraded sway bars??
Richard
Old Apr 7, 2003 | 03:31 PM
Turbo]['s Avatar
98 E430
a stiffer ride, and most of all, you lose alot of the body rolls.
I am also looking in to replacing my sway-bars, but the only manufacture I know that have a full set for the E430 is Eibach. I believe it's around $400. Or you can get the bars off of a E55.
Not sure which other manufacture have them available immediately. H&R should have their set out by Summer.
Old Apr 7, 2003 | 11:58 PM
Turbo][
I had spoken to Sander@ TWS...his recommendation was to replace my OEM shocks first with Bilstein sports and then upgrade the sway bars if needed. He sells Brabus sway bars for $500 + install.
Bilstein vs Koni...what are your impressions??
Also, did you ever get in touch w/Randall in regards to the BMC CDA?? I'm still awaiting mine.
Richard
