Best track tire for the C63?
Old Aug 8, 2010 | 03:55 AM
myblkc63's Avatar
2009 C63 AMG
What is the best track tire for the C63?
I have used the Yokohama A048 and the Michelin pilot sport cup. The Yoko lasted 4 track days and several hundred road miles while the cups only lasted one track day and less than 100 road miles. The cups did appear to be faster and maybe that is because of their stiff sidewalls because on paper they are not as soft/sticky as the yoko's. Then again, I could just be getting better at driving.
Anyway, I need to order a new set and am looking for recommendations and experiences.
Thanks in advance.
Old Aug 9, 2010 | 05:29 AM
Jochen's Avatar
2003 Dodge Ram 1500 SLT
Are you going with stock wheel and tire sizes?
Try this:
pirellityre.com
Pirelli fabricates good tires for Mercedes-Benz.
If a tire doing good on a Corvette for example, doesn't mean the same tire is also good for a Mercedes.
Mercedes in Germany recommend Pirelli, Michelin and Continental tires...
Old Aug 10, 2010 | 05:52 PM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
1 day for sport cups ... I had a set which went 10 track days and an untold number of AutoX runs .. in the end I put almost 5000 miles on them .... in a car which weight almost 4000 pounds wet
what alignment specs are you running?
Old Aug 16, 2010 | 02:22 AM
myblkc63's Avatar
2009 C63 AMG
The tires were actually OK except for a couple holes that had developed that went all the way through to the cords. One was about the sice of a quarter andante other a nickel. I'm trying to email you pictures. At this point I'm willing tom give them another shot but wanted to explore the optinos first. I need to make anorder pretty soon. The problem aI m running into is that I can't find many options for the stock rims. I need a 235 front and don't want to go 245 as I thin they will actually perform worse at that size due to the stock rim width.
