Rotor Coning???
Old Apr 23, 2003 | 03:04 PM
nukblazi's Avatar
Question LUKE- Rotor Coning???
Luke-
I am experiencing a rotational vibration, noise and feel increases or decreases in sync with speed.
I was wondering how to tell if the disk is "coning". Upon visual inspection, the outer brake pads seem to be worn on an angle. The outer portion of the pad, further from the hub, is thinner then closer to the hub.
Is this normal or an indication of coning?
Old Apr 23, 2003 | 07:33 PM
nukblazi's Avatar
bump-
Has anyone else noticed this on their pads?
Old Apr 24, 2003 | 09:56 AM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
the pad wear you mention could be an indication of a coning rotor or caliper flex .... typically you only see those 2 things under extremem conditions ... have you been to a DE or track day or something ??? I would suspect caliper flex when under extreme use before rotor coning
the only way to tell for sure is to measure the rotor off of the car with a micrometer
Old Apr 25, 2003 | 02:49 AM
nukblazi's Avatar
Typically use for me is commute to and from work. I drive hard though, and I tend to break late. I also have 27k on the car. I've only done two time trials, that was last year though.
So with the micrometer, I am just looking for anomalies? Or decreasing thickness towards the outer edge of the rotor?
Old Apr 25, 2003 | 08:15 AM
you will be looking for the distance from the surface of the hat area to the rotor surface to change ... typically getting smaller
