Does wheel on GL320 2008 fix on base model ML 350 2006? please help me on this.
Old Mar 25, 2011 | 09:04 AM
MoonLite's Avatar
ML350 '06 & S430 4Matic '04
I found the set of this wheel GL320 2008 and like to buy to upgrade my base ML350 2006. Do I need to do any modification in order to install them? They are selling for 200/set. How can I check if they are bend wheels? Please give me some knowlege/help and thanks so much for your time. Oh one more question. What is the best fix tire size for this wheel? or any option for tire size.
Old Mar 25, 2011 | 10:15 AM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
those should fit fine
Old Mar 25, 2011 | 11:49 AM
MoonLite's Avatar
Thank Luke
Can I reuse my original bolts ? Does my ML350 2006 has TPMS? if yes can I resue them on new wheels? what about tie size for these wheels 8Jx18H ET53. Please give me some clearly info. Thanks so much again for your time.
Old Mar 25, 2011 | 04:16 PM
use one of these tire sizes
255/55-18
265/55-18
your ML has an indirect TPM system (no sensors required)
don't know about the bolts
Old Mar 25, 2011 | 04:33 PM
MoonLite's Avatar
So I just need to buy tire and not worry about sensors that right? just make sure before I pay them.
Old Mar 25, 2011 | 04:38 PM
correct
Old Mar 29, 2011 | 01:51 PM
MoonLite's Avatar
255/55-18
265/55-18
Luke,
Can I use performance tire 245/55 R18 on this GL wheel 8Jx18H ET53 for my ML350 2006. Thanks again.
Old Apr 12, 2011 | 01:10 PM
MoonLite's Avatar
255/55-18
265/55-18
Luke, I try to order tires fr you on April 6th (last day of promotion $70 rebate) but you was off so I ordered them from tirerack anyway. Thanks
The bolts are too short for GL320 18" wheels.
Now, Anybody has OEM wheel bolts left and want to sell ? just let me know. Thanks
BTW before I order tires I checked with MB part dept gave them both wheels OEM part # and they told me I can reuse lug bolts I am so mad they give me wrong info. I also check with 2 others website and both websies selling lug bolts gave me the same bolts part # for model/year cars I entered.
