c36 rolling over right rear tire
Old Feb 12, 2002 | 05:22 AM
steve s's Avatar
1996 C36 AMG, 1995 Volvo 850 Turbowagon
this happens when cornering too hard. well, at least that's what i think is happening. i hear this "poing/doing" noise from right rear. tire pressure @ 36 psi. alignment all within spec (from computer data). any ideas? happened on original factory installed bridgestone s-01 expedia and on brand new bridgestone s-03 potenza
Old Feb 12, 2002 | 10:53 AM
Mach430's Avatar
You could lower your car to give it some negative camber.
Old Feb 12, 2002 | 03:05 PM
steve s's Avatar
it already has roughly -1.0 camber...
Old Feb 12, 2002 | 04:17 PM
Howard's Avatar
2000 Clk 430
Steve,
Mark your tire(s) with either white chalk or white shoe polish where the sidewall meets the tread. Make a mark that goes down the sidewall a few inches. Now go fast around some corners. Look at the mark to see how far the tire rolled over. There is usally a symbol on the sidewall that marks the spot where the max rollover should be.
By raising or lowering your pressure you can control where the tire rolls over. I hope this makes sense!
Personally, I don't think your tire is rolling over too much unless you are really pushing hard, to the point where you are understeering badly.
Let us know what you find.
