W216 TPMS Reset
2. Switch on the ignition.
3. Press button < or > on the multifunction steering wheel to select the menu Service.
4. Press button ^ or v to select Tire Pressure.
5. Press the button 'OK' to confirm. You will see the current inflation pressures for each tire or the
message:
Tire pressures displayed after driving a few minutes
6. Press button v. The message:
Use current pressure values as new reference values.
To confirm press “OK”
appears in the multifunction display.
7. Press button 'OK'. The message:
Tire pressure monitor restarted
appears in the multifunction display. After a few minutes of driving, the current tire inflation pressure
values are accepted as reference values and then monitored.
8. If you wish to cancel activation press 'exit'
http://cgi.ebay.com/ebaymotors/ws/eB...#ht_500wt_1182
PS Guess I was right to put locks on the G wheels before I went to the recent NYC AMG preview!
Www.mymercedesparts.com
Also, have you called Luke directly? TR is one of the largest sensor users in the country.
