Luke need your advice
Old Jun 16, 2003 | 12:05 PM
E320's Avatar
Luke,
Will 18x9 all around et35 AMG mono2 will fit ML class without a problem?
TIA
Old Jun 16, 2003 | 02:41 PM
Harris's Avatar
I dont think those wheels will fit. M-class uses wheels with ET52 offset!!
Old Jun 16, 2003 | 03:01 PM
E320's Avatar
Yes the stock Ml uses ET52 offset but im talking about aftermarket wheels.
Old Jun 16, 2003 | 04:26 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
The offset isn't the issue.
AMG Mono II is for 12mm lugs, the M-class uses 14mm lugs. You may not even be able to get the bolts through. Wait, let me go try.
Yeah, the bolts don't even go through. The holes in the wheels are only 12.5mm, and the bolts are 14mm diameter.
Secondly, the load rating on the Monoblock II is probably not high enough for the M-class.
I ran 18x9" ET35 wheels on my M-class (these wheels were spec'd by Tirerack way back when), with 285/50R18 tires. I had fender flares so the tires didn't stick out, if you don't have flares that size may stick out some. 17mm difference in offset really doesn't make much difference in that HUGE wheel well.
I guess you're going to have to find someone else to get those rims... why don't you just straight sell the two you have?
-s-
Old Jun 16, 2003 | 04:30 PM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
with the intended use of the ML ( it's a truck) the AeroII Monoblock wheel will not properly meet the vehicle requirements due to the added load capacity of the ML
so ... no
Old Jun 16, 2003 | 04:38 PM
E320's Avatar
-s-
Thanks for clariying,You might be interested for your C43?
Old Jun 16, 2003 | 04:39 PM
E320's Avatar
What MB car will fit 18x9 et35 all around?
Old Jun 16, 2003 | 08:20 PM
scorchie's Avatar
Send me an e-mail with your price (where are you located? maybe with shipping).
-s-
Old Jun 17, 2003 | 02:23 PM
E320's Avatar
Dean,
you got mail.
