Ok, now I get a headache every time i drive
Old Jun 30, 2003 | 10:41 AM
Kar don's Avatar
Mercedes-Benz
I need the quietest softest riding tire in size 215/45 R17. I want something that stays quiet even after 10k miles, I am fed up with my bridgestone RE040 tires. They ride stiff now, are so loud, and start to squeal on corners. With over 50% tread left I am ready to throw them away. Would like to still have good handling but quiet and soft ride are priority!
Old Jul 1, 2003 | 09:04 AM
Kar don's Avatar
Mercedes-Benz
I am still hearing mixed reviews on the conti extreme contact, does anyone have them?
Old Jul 1, 2003 | 10:05 AM
JamE55's Avatar
Out Of Control!
Ali
Try Continental Conti Sport. Friend of mine recommended them if you want something quiet.
Old Jul 1, 2003 | 10:13 AM
Harris's Avatar
Ummm....seems like I still cannot convince you to get T1-S?
Old Jul 1, 2003 | 11:09 AM
Kar don's Avatar
Mercedes-Benz
tirerack doesn't sell it and I have no idea where i can buy it. Don't think it is available in 215/45 R17 either. James, I always hear bad things about the conti sports.
Old Jul 1, 2003 | 11:30 AM
JamE55's Avatar
Out Of Control!
Really? HHmm
Old Jul 1, 2003 | 11:52 AM
KWiK's Avatar
2002 C230 : 2007 C230
If you didn't need such a narrow tire, I would say get the Yokohama AVS dB. It is a very quiet tire.
Old Jul 1, 2003 | 12:45 PM
Kar don's Avatar
Mercedes-Benz
I think 225/45 17 will fit on my rims. They are 17x7. I know a few people that have done it.
Old Jul 1, 2003 | 02:51 PM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
you are doing yourself a dis-service if you fail to check out the Firehawk SZ50 EP from Firestone ... it would be my 1st recommendation
tire search
Old Jul 1, 2003 | 03:29 PM
Kar don's Avatar
Mercedes-Benz
tire search
any sort of guarantee with these tires? would u recommend i get 215/45 ZR17 or 225/45 ZR17. The car came with 215/45 ZR17 and 17x7 wheels. Also in the review it says FIRM ride quality, I don't want firm! I already have a super stiff loud ride with my half worn bridgestone potenza RE040.
Old Jul 2, 2003 | 10:17 AM
the ride quality of the SZ50 is excellent ....
Old Jul 2, 2003 | 01:37 PM
Harris's Avatar
T1-S does have both 215/45/17 and 225/45/17, check in here: http://www.toyo.com/tires/tire_specsheet.cfm?id=2 I can get them for you if you want.
Old Jul 2, 2003 | 09:10 PM
Kar don's Avatar
Mercedes-Benz
sure! quote me some prices. do u think i should get the 225 over the 215? Wider tread and taller sidewall (better grip and better ride? or is this completely wrong)
Old Jul 3, 2003 | 09:07 AM
ima55r2's Avatar
2018 Mclaren 720s, 2021 Aston Martin DBX
I got my Toyos from here and they have your 215s in the T1-s for $148.
http://www.treadepot.com/td.c/orders/index.html
Old Jul 3, 2003 | 02:35 PM
Harris's Avatar
If you are not going to change anything to your car, i.e. suspension, wheels, you may just stick with 215. A bit cheaper too. I need your e-mail address or would you mind send me an e-mail?
Old Jul 3, 2003 | 03:13 PM
Kar don's Avatar
Mercedes-Benz
AlBoston@mbworld.org the reason i was considering 225 is because the taller sidewall would mean more tire to soak up bumps.... do u think this is worth it?
Old Jul 5, 2003 | 12:34 PM
Kar don's Avatar
Mercedes-Benz
brandon at tirerack told me to get conti CH95s
Old Jul 6, 2003 | 11:59 AM
breastroker's Avatar
2003 C230 K , 2001 ML320
Both the Firehawk SZ50 EP and the Yokohama AVS dB are very quite tires, and very soft riding. Had both on my Lincoln Mark VIII. Both were much more quiet than any other tire I have used, and I went through 4 different tire brands on that car.
I much prefered the Firehawk SZ50 EP because it is a much more responsive tire (sporty) than the Yokohama AVS dB. Both remained quite through entire tire life, 18-20,000 with the Firestones. Only at 15,000 with the Yokohama and there is 35% tread left. Still quiet.
I have learned to accept Luke's recommendations, he has never steered me wrong.
You will love the Firehawk SZ50 EP, get the 225's.
