Yokohama AVS Sports - Good/Bad???
Old Aug 8, 2003 | 05:09 PM
mmgrad's Avatar
W213 '17 E43 ///AMG - W211, W208 no more
Can I get some opinions about the Yoko AVS sports??? How are they? do they perform well? How do they compare to other max performance tires?
Pros & Cons???
I hear they grip well, but treadwear (rated @ 180) is horrible...
I'm looking for 235/35/19 & 265/30/19 Combo....
Lastly, does anyone know the weights for these tires in that combo?
Thanks!
Danny
Old Aug 8, 2003 | 05:17 PM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
very good performance
rather noisey ride quality
wear fast
Old Aug 8, 2003 | 05:28 PM
mmgrad's Avatar
wear fast
Luke,
based on memory, I believe you only have 3 different tires that would work for me, right?
Yokohama AVS Sport
Dunlop P9000
Pirelli PZero Nero
What is your ranking for these?
Can you tell me their respective weights too? Thanks!
Old Aug 8, 2003 | 05:30 PM
#1.) P-Zero Nero
#2.) Sport 9k
#3.) AVS Sport
Old Aug 8, 2003 | 05:31 PM
mmgrad's Avatar
#1.) P-Zero Nero
#2.) Sport 9k
#3.) AVS Sport
thanks! do you know the weights of each in the sizes i need?
Old Aug 17, 2003 | 01:45 PM
derek m's Avatar
02 CLK55, 07 E92 335 ProCede
on my clk, with the same avs tires and size as your set up, lowered with H&R, i found it to rub quite abit. Performance was decent. I switched back to the Toyo same size and have near to no rubbing at all, which I am more found of all around.
Old Aug 19, 2003 | 09:44 AM
sounds like you have wheels with an offset that is too low
Old Aug 19, 2003 | 02:21 PM
mmgrad's Avatar
sounds like ur car might be lowered more than mine.
with a 2" drop, i'm noticing minimal contact with the inside of the fenderwell cover... just a little... but it doesn't make contact with my fenders or anything. I think an additional 2mm spacer would have corrected the problem for me.
