H&r Spring Install Help
Old Feb 11, 2004 | 05:42 PM
kaps's Avatar
2001 CLK55
i am installing h&r springs onto my 01 clk55 with a buddy. will the stock shocks be fine with this set up or will i need to replace the stock shocks? also, is there anything i need to be weary of or look out for after the install? i.e. alignment?
PLEASE HELP.
Old Feb 12, 2004 | 08:54 AM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
performance springs will cause the stock shocks to wear out faster and you will need to get an alignment after the install
Old Feb 12, 2004 | 11:30 AM
Mach430's Avatar
Since you will already be taking the suspension apart to install the springs, I would suggest that you install a set of Koni Adjustables or Kleemann Speed-Sensitive Shocks at the same time. As Luke mentioned, your stock shocks will wear our prematurely, and you will have better performance/comfort with a shock better suited for the springs.
Old Feb 14, 2004 | 02:02 AM
xxbenzc230kxx's Avatar
is not yet completed
how does da H&R ride with the upgraded shocks? bouncy? stiff? honda like feel? or feels stock?
Old Feb 14, 2004 | 04:38 AM
theine's Avatar
2014 GLK250 BlueTec & 2009 ML320 BlueTec
With H&R springs on, how different will be the ride between the koni's and the kleeman.
