Will 19x9s fit w211 front?
Old Feb 24, 2004 | 11:25 AM
dstrnturbo's Avatar
Need som help.. Will 19X9" wheels w/ a 35mm offset work on a w211 e320? If so, what tire size would you recommend? Thanks in advance.
Old Feb 25, 2004 | 12:54 AM
dronell19's Avatar
E46 330i
I'm no expert, but it sounds quite aggressive. May still fit, though...
Old Feb 27, 2004 | 02:20 PM
CANAUTO's Avatar
Not recommend for the front though. BTW, which brand are you getting if you don't mind I ask?
Old Mar 1, 2004 | 04:35 PM
WTALYFF's Avatar
W211, landcruiser
19 X 9
i have 19 x 9 in fronts w/ 35 offset, (carlsson 2/6) tire size is 245/35/19 no problems w/ H & R springs
Old Mar 1, 2004 | 05:05 PM
moa4r's Avatar
S4
Re: 19 X 9
no rubbing problem, even after you lowered??? did you modify your fenders at all??!!! thanks
Old Mar 1, 2004 | 09:32 PM
WTALYFF's Avatar
W211, landcruiser
19'wheels
no rubbing at all w/ no fender mods. send me your email address via PM i'll have pics by thursday
Old Mar 3, 2004 | 01:49 PM
clkal's Avatar
01' CLK55
if the W211 has the same set up as the W209, I know for a fact that a 19X9 rim w/ a 35mm offset will NOT fit w/o a spacer. I sold my set of LM-1's to a guy who bought a brand new CLK500. He had to buy 7mm spacers to make the front rim fit.
Old Mar 3, 2004 | 01:58 PM
moa4r's Avatar
S4
the need for spacers usually depends on the offset though
Old Mar 3, 2004 | 02:01 PM
moa4r's Avatar
S4
Thumbs up Re: 19'wheels
check your pm!!
Old Mar 3, 2004 | 02:02 PM
clkal's Avatar
01' CLK55
doesn't lorinser just make one offset rim and just include the necessary spacers for each application?
Old Mar 3, 2004 | 02:06 PM
moa4r's Avatar
S4
not sure about lorinser, but a lot of wheel manufacturers make the same wheel in many different offsets for various applications...
Old Mar 3, 2004 | 02:13 PM
Harris's Avatar
The main problem here is not about the offset (although it does have some kind of affect). The problem is about the WIDTH of the wheel. A 19x9 wheel with ET35 offset can be fitted on a W211 (BUT the tire might have a chance hitting the struts).
The reason why spacers is needed on a CLK500 with the LM1 is because CLK500 has big calipers in the front. The W211 doesnt. Also, W211 and W209 wheels are theoretically not interchangable because of different bolt size (but that doesnt mean it cant be done).
People should stop commenting if they're not sure of what they are talking about.
Old Mar 3, 2004 | 02:43 PM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
that's what Carlsson used to do
