I Need New Tires: Michelin Pilots Sports or Yokohama AVS ES100?
Old Apr 19, 2004 | 06:39 PM
SoCalCLK's Avatar
2017 W205 C43 AMG
Question I Need New Tires: Michelin Pilots Sports or Yokohama AVS ES100?
I need to get a new set of tires for my stock 17" AMG Wheels on my 2002 CLK 430.
The current tires (Michelin Pilots) have 18,800 miles on them and are ready for retirement. I was shopping around and the price is a big factor between the two.
Michelin REAR = $192 each
Yoko AVS ES100 = $130 each
Michelin FRONT = $170 each
Yoko AVS ES100 = $112 each.
Which brand is better? Help!
Old Apr 19, 2004 | 11:56 PM
allenjdmb's Avatar
E 63S Wagon Renntech, E55 Renntech, SL65, SL 55 030, ML, bunch of old ones--they come, they go...
Not much contest here...
the Michelin is superior, but costs substantially more. If you're looking for the Michelin, just make sure you avoid the Pilot A/S and get the pilot sport 2. The A/S has the right pull problem that Michelin denies. The Yokos are not bad, by the way. If cost was no object, i'd definetly take the Michelins. The Yokos dont ride quite as well, won't last quite as long, and are noisier, but not a lot. But, as with most things in life, money usually is an object....
Old Apr 20, 2004 | 11:23 AM
SoCalCLK's Avatar
2017 W205 C43 AMG
Thanks, Allen.
I did some research and found your thoughts to be accurate!
Old Apr 20, 2004 | 03:58 PM
ldangeli's Avatar
EFF YOU JACKIE
I have the Yokos on my 430. 18 x 9's and they are pretty loud. I would go a little more expensive next time to avoid the noise. And I do mean loud..
Old Apr 20, 2004 | 04:50 PM
SoCalCLK's Avatar
2017 W205 C43 AMG
Thanks, buddy.
I appreciate the input..Michelins it is...
Old Apr 20, 2004 | 06:32 PM
ldangeli's Avatar
EFF YOU JACKIE
No prob. The only thing I can say is, if you don't mind the noise, the composition is pretty good and tread life has been great.
Good luck!
Old Apr 20, 2004 | 10:20 PM
CHB's Avatar
CHB
'79 300D, '85 300Dt, '99 CLK430
Re: Not much contest here...
Originally posted by allenjdmb
just make sure you avoid the Pilot A/S The A/S has the right pull problem that Michelin denies.
What is this problem? I have them on my car, and I love the tires.
