Wheel Fitment HELP
Old Aug 4, 2020 | 03:02 PM
Ducatista19's Avatar
‘17 C300 coupe
Wheel Fitment HELP
Hi All,
I recently bent a front wheel on my GLE 53 Coupe and turns out dealer has no idea when a new one will be available. I am looking for a new set of wheels but can't find any that have the same 51 front and 47 rear offset.
Can anyone help explain what I can do to make other wheels fit?
Thanks!!
Old Aug 4, 2020 | 04:17 PM
MBJIMBO's Avatar
2018 E300 Sport:Current 2015 Mercedes Benz C300 Sport- Gone.
Check with the tuners, like Brabus, typically there is a flexible tolerance in wheel offsets when you range something from a factory application to an aftermarket one.
This is why aftermarket wheels tend to look more aggressive on a vehicle compared to a stock fitment, the aftermarket is usually 10-15mm more aggressive, so if your factory uses an ET51 Front, you should be able to fit something in the same size range with a ET40-45, and the rear being a ET47 should allow a 35-40mm offset wheel.
Some aftermarket wheels might be a different size meaning a 8.0 with a 51 could accept a 8.5 with a ET40.
Again, look up what Brabus would offer for your model, and that should be the Bible to go by as they are required to meet the German TUV approval just like the factory is required with the AMG wheels. This goes for tires as well.
Old Aug 5, 2020 | 06:35 PM
‘17 C300 coupe
Unfortunately, Brabus doesn;t have anything with it being a '21 model.
What would you think about going from stock:
Front - 21X 10" (width) X 51 offset
Rear- 21 X 11" width X 47 offset
TO
Front - 21 X 9" (Width) X 25 offset
Rear- 21 X 10.5" (Width) X 41 offset
Old Aug 5, 2020 | 06:44 PM
MBJIMBO's Avatar
TO
No, absolutely not! Those sizes seem like a car fitment, not load rated for the SUV application.
I will find out the rim application for you from Brabus.
Old Aug 5, 2020 | 06:48 PM
MBJIMBO's Avatar
https://www.brabus.com/en/tuning/ove...14-167-bp.html
Old Aug 5, 2020 | 06:52 PM
‘17 C300 coupe
Thanks!!
Old Aug 5, 2020 | 07:36 PM
‘17 C300 coupe
I’m not finding any wheels similar to the Brabus specs.. but I did find:
Front: 21x10x42
Rear: 21x10.5x41
Thoughts?
Old Aug 24, 2020 | 05:42 PM
HaydnM's Avatar
GLE400 W167
Check out Vossen website, will manufacture to the offset you require
no wheel spacers 👍
Old Aug 24, 2020 | 06:32 PM
MBJIMBO's Avatar
Front: 21x10x42
Rear: 21x10.5x41
Thoughts?
Not sure what Brand, maybe that is a multi pc setup, but Brabus shows a 21x10.5 ET50 Front and rear, with a 285/45-21 tire front and rear.
If you were to run a 10" front and a 10.5 rear, that means you would have to try and match a staggered tire, or if you used the same recommended 285/45-21 then the front tire would look bigger as it would sit more square or pinched on the rim, and the rear would then stretch and lay down the sidewalls giving it a less aggressive look. If I were you I would look for wheels that are in the same spec range as Brabus recommends as they have TUV Tested and approved their application, which also means the tires in that size are approved as well.
Hope this helps.
