Cut Rotors ?
Old Feb 28, 2005 | 09:36 PM
unsobill's Avatar
1989 MBZ 300e
Cut Rotors ?
My front rotors seems damaged ... Should i cut them for 15$ each and install brand new original pads on them ?
Old Feb 28, 2005 | 11:46 PM
m117968's Avatar
96 S600 Euro, 91 560 SEC, 88 300TE, 87 560SEL, 86 560SL, 80 280SE, 64 Austin Healey 3000MIII
OK, two things....One, to cut a rotor properly takes a good 45 minutes to measure and set up.. so who ever is offering to cut your's is a hack. 2nd, MB Specificly states that their rotors are not to be cut.
124's rotors are a on a small/thin side to begin with, all cutting them will do is make them even more prone to warpage. Considering that I sell front's for 40 a side cutting makes zero sense.
Jonathan
Old Mar 1, 2005 | 03:57 AM
unsobill's Avatar
1989 MBZ 300e
you got ebay listing?
is yours rotors drilled or ... ?
Old Mar 1, 2005 | 05:02 AM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Can you tell me where MB specifically states that their rotors are not to be cut? Because I have a lot of documents from Mercedes that specifically give the requirements for turning the rotors (the exceptions being the cross-drilled rotors, which in the grand scheme of things, are relatively new). The problem is that most rotor lathes do not meet the tolerance requirements that Mercedes sets out.
But I'd like to read more about these "statements" that MB makes.
-s-
Old Mar 1, 2005 | 08:02 PM
Brian Felts's Avatar
E 320
Where can I find these rotors for $40.00. Do you sell other parts that cheap?
I did turn my rotors on my E 320 and it came out fine. There is a thickness limit stamped in the rotor. The " Hacks" have turned rotors for many years for Yugo's to Rolls and they are fine as long as you stay within the limits. There is no mechanical or metallic diffrence in the rotor after they are turned. That rule was just laid down so the Dealerships could make more money.
Brian Felts
