FS : Genuine Carlsson 19" Rims (staggered)
Selling a set of Genuine Carlsson 19" Staggered made by Ronal.
Front 19x8.5" ET40
Rear 19x10" ET45
Fits 202, 203, 210, 220, 124, 129, 140, etc
No cracks, no bends. Has slight curbage (purely cosmetic). Rims in original factory finish. Never repaired, repainted or refurbished. Comes with centercaps and hubcentric rings. No tires
![](https://i14.photobucket.com/albums/a317/z168/Rimsrims/th_DSC04171.jpg)
![](https://i14.photobucket.com/albums/a317/z168/Rimsrims/th_DSC04170.jpg)
![](https://i14.photobucket.com/albums/a317/z168/Rimsrims/th_96875674768rt.jpg)
![](https://i14.photobucket.com/albums/a317/z168/Rimsrims/th_DSC04172.jpg)
![](https://i14.photobucket.com/albums/a317/z168/Rimsrims/th_DSC04173.jpg)
$850 picked up
on my W140
![](http://i14.photobucket.com/albums/a317/z168/myW140/2764269071_33c7e0b7e6.jpg)
Front 19x8.5" ET40
Rear 19x10" ET45
$850 picked up
on my W140
![](http://i14.photobucket.com/albums/a317/z168/myW140/2764267139_ba793c864f.jpg)
Ive seen these fit on a 203 no spacers. Seen them as well on a 202 and 210 but without knowing the owners, I wasnt sure if there were spacers. Eitherway, thanks for pointing that out.
I don't know about the rears but I'm running a set of 19"x8.5" ET40 on the front of my W210 with a Carlsson 3mm hubcentric spacer so its effectively ET37. The seller mentioned hubcentric rings. If they are 3mm it should work on the front.
06 CLS55 Renntech stage 5, 04 CL600 ( will miss ),02e55 , 11 R350
I meant no offense at all , I am sure you will be swarmed with emails from interested parties regarding fitments, thats what happens with wheels. You mention Hubcentric rims, I guess you mean hubcentric spacers, if memory serves then they should be Carlsson specific, meaning they snap onto the wheel hub itself with a tension ring, it will help to point out if they are for the rear, front or both and what is the thickness of these spacers. The 40/45 offsets are for sure for a W140 , W220, W221 chassis with no modifications, of course will spacers , anything can fit. I have these wheels on one of my cars , and they are gorgeous . Best of luck with the sale.
good luck - have a 202 and was told i can't go any wider than a 8 inch up front. I have set of the AMG III 211 wheels and its tight.
Location: South Coast Metro/Cerritos/Yorba Linda California
'05 C230K '10 GLK350 '13 SMART
GL w/ sale I have a set of these. 12mm F 10mm R carlsson adapters are needed for w203 fitment.
Thanks for the added info
and yes I failed to mention there is a pair of hubcentric spacers included but only a pair (12mm). and I didnt make a mistake about the hubcentric rings since I needed to fit them without spacers to from 66.5mm to 76mm centerbore
sorry for the late reply. PMs also replied
Yes I am willing to ship internationally BUT i will not be liable for any customs charges you will incur.
W140 bolt size is 14mm diameter while everything else is 12mm
