Sponsored by: MB Part Haus
19x8x5/9/5 SL63 reps $699 NEW by PowerWheels Pro
Old May 9, 2009 | 11:41 AM
powerwheelspro's Avatar
Former Vendor of MBWorld
E320
Hi Andy,
It has been posted.
Thanks!
Vassili
Old May 9, 2009 | 11:45 AM
mekantor's Avatar
2003 E55 AMG; 2013 GL550 4Matic; 2003 CL600
Is it possible to get wheels with different inner colors directly from you, like black instead of that gray?
Old May 9, 2009 | 03:13 PM
E320
mekantor: Unfortunately we don't powdercoat or paint wheels cause we don't want to compromise the factory finish as we would no longer be able to offer the warranty we normally do.
Regards,
Old May 9, 2009 | 04:58 PM
m4xm1l10n's Avatar
BMW F02 (750Li) F10 (550i)
Originally Posted by powerwheelspro
Some excellent questions.
We have visited many factories with various degrees of quality that we rejected right off the bat. We work with the best one that has all the production controls in place to ensure consistent wheels. They make wheels for Honda, GM and VW, so all our wheels use the same low pressure casting process.
All of them have clear coat on them to protect them from the road grime and brake dust. We have NEVER had an issue with our wheels. In fact we are so confident they will last we offer unlimited warranty for manufacturing defects and two year on the finish. It is hard to objectively offer any more on something that is so susceptible to outside elements that it would make it virtually impossible to prove any finish etching was not due to user neglect.
In addition, it is our responsibility to ensure fitment on your car. If for ANY reason the wheels don't work for you we will not only give you 100% refund including shipping, but we will also pay for the shipping back to us.
As you can understand we wouldn't offer such generous terms if we were not confident in our wheels. We try to offer the same service we would expect to receive as customers, it really is as simple as that :-)
Thanks,
You got me sold man I need some bigger wheels for my S class
Old May 9, 2009 | 05:07 PM
mekantor's Avatar
Regards,
What does the warranty include? If the wheels were to be powdercoated elsewhere, would that void the warranty?
Old May 9, 2009 | 05:31 PM
jturkel's Avatar
02 C32 AMG
what is the weight of these rims? are you sure it wont fit C32s?
Old May 9, 2009 | 05:35 PM
  #32
m4xm1l10n's Avatar
I believe it would be voided .
Old May 9, 2009 | 06:09 PM
  #33
efx1's Avatar
C350
i thought the lower the offset, it pushes the wheel out more towards the fender
Old May 9, 2009 | 06:40 PM
  #34
m4xm1l10n's Avatar
That is correct the off set listed for these wheels are good for S CL E ETC it will go on SL R230 & CLS but not aggressive enough
Old May 10, 2009 | 09:18 AM
  #35
E320
To clarify, the warranty covers to thing:
1. Finish, two years. If the wheels are powder coated the paint and clear coat are obviously not the way it came from the factory so if the shop that coated them didn't do a good job you will have to take it back to them.
2. Manufacturing defects, if the wheels arrive with scratches, gouges or anything that should not be there, we will absolutely replace them no questions asked. Just a background piece of information, the wheels go through x-ray at the factory to ensure there are no hairline cracks, air pockets or anything that would compromise the structural integrity of the wheel.
The wheels are about 31 front and 33 rear, same as OEM as they come out of the same process, low pressure casting and they use the same amount of metal.
Regarding offset, EFX is correct, the lower it is, the farther out the wheels will sit. The SL is the only MB platform that has an offset around 20mm, so customers that bought these had to use spacers to push them out and clear their brakes.
These will also fit the R & M class.
They WILL fit the C32, but you might have to use spacers in the front to clear your brakes that's all.
Happy Mothers day to All
Old May 10, 2009 | 11:21 AM
  #36
m4xm1l10n's Avatar
Not mean to disagree with you but i think the CLS has the most aggressive off set between all the MB .
R230 SL 18" 35MM F 40MM R (My SL now 20" 25mm F 30mm R way to aggressive for the S500 )
R230 SL55 18" 31MMF 33MM R
CLS 18" 25MM F 28MM R
I actually like the CLS off set on the SL and that is what i use , for example I had the SL Launch edition wheels on my S500 18" 35MM F 40MM R with no problem , but the CLS 25MM F 28MM R it stuck out and rub the rear fender .
Old May 10, 2009 | 01:17 PM
  #37
jturkel's Avatar
02 C32 AMG
and what is the weight per rim?
Old May 10, 2009 | 06:51 PM
  #38
E320
m4xm1l10n: I see, thanks for shedding some light on this. From what you mention:
The S class is all good
Regarding the SL, our information was obsolete as for the R129 one would indeed need spacers as the offset is around 25mm. The R230 I see has less aggressive offset, that's great.
We know for a fact that the 35mm will fit the E class with the AMG brakes which has 30mm offset without rubbing on anything. They will be 5mm recessed though, not a big del, as it will be barely visible.
Didn't realize that the CLS has such an aggressive offset!
Thanks again for the info!
jturkel: I actually did respond to your question it was in the middle of the post, buried in the middle, the wheels are about 31lbs front and 33 lbs rear, same as OEM as they come out of the same process, low pressure casting and they use the same amount of metal.
Thanks guys!
Old May 10, 2009 | 07:05 PM
  #39
m4xm1l10n's Avatar
All good , I'll be getting a set soon Question on the 20" 808 . When you post the off set on the 20x8.5/9.5 at ET43 is that all around ?
Old May 10, 2009 | 08:41 PM
  #40
07e350's Avatar
2007 E350
Can you post some picture of the wheel on the E class?
Old May 10, 2009 | 10:31 PM
  #41
jturkel's Avatar
02 C32 AMG
m
Thanks guys!
sorry. i just briefly skimmed over it and missed it. thx!
Old May 10, 2009 | 10:39 PM
  #42
E320
m4xm1l10n: The 20" 808 are 43 all around. Thanks
07e350: Unfortunately I have not been able to find one online of the SL63 wheels on an E class and we have not received one from our customers.
jturkel: No worries
Old May 16, 2009 | 12:50 PM
  #43
Outkasted24's Avatar
Correction, Drove An '05 C230 Kompressor SS
So these are staggered? Is there any way you can post pics of the 19.8.5 & 19x9.5 next to each other? So we can see the Concave difference.
Thanks in Advance.
BTW: So It's $699 + $85shipped?
Old May 16, 2009 | 02:49 PM
  #44
Gondon's Avatar
02 S500 Sport
Do you have the gunmetal S65 rims in stock?
http://cgi.ebay.com/ebaymotors/19-S-...lenotsupported
Old May 16, 2009 | 07:29 PM
  #45
E320
Outkasted24: Thanks for your interest, actually we are out of the 19s on this style.
We do have them in 18s, I will take pictures tomorrow and post them to show the concavity difference.
Hi Gondon,
Unfortunately we only have them in 18x8.5 non staggered and the finish is silver with machined lip:
Thanks,
Vassili
Old May 17, 2009 | 10:52 PM
  #46
E320
As promised here are these wheels in 18x8.5/9.5 that we have in stock:
Thanks,
Old May 26, 2009 | 08:09 AM
  #47
theboogers's Avatar
2020 S560,14 ml350, 03 sl55, silver, pano, slr cams, evo headers, lsd, 2019 s63 cab.
Post when you have tried these in 19" staggered on a R230 SL. i guess they will not stick out enough to work on the Newer SL?
Old May 26, 2009 | 01:13 PM
  #48
E320
Will do.
Thanks,
Old May 26, 2009 | 03:13 PM
  #49
m4xm1l10n's Avatar
It will work with the R230 SL as the stock 18" wheels on the SL500 Are 35MM Front and 40MM Rear . These wheels are 35mm all around and vuala!!!
Old May 26, 2009 | 03:43 PM
  #50
E320
Good Work M4X...!
